LEAN POP!
Old Apr 26, 2004 | 02:07 PM
krivera's Avatar
krivera
Default LEAN POP!
OK... How many of you guys have heard of "LEAN POP"? I have heard of pre ignition or detonation but lean pop is something new to me?
I am working on a truck that is running a vortech and he says at low rpm he gets lean pop? So I listened to this "LEAN POP" and it sounded like this spark plug missed or his spark plugs wires where arcing? But I wanted to see what the forum thought?
Old Apr 27, 2004 | 04:40 PM
krivera's Avatar
krivera
Default Re: LEAN POP! (krivera)
anyone heard of lean pop?
Old Apr 28, 2004 | 07:39 PM
red-y's Avatar
red-y
Just light beer in texas, no lean pop or soda allowed. :p:
Old Apr 29, 2004 | 12:01 AM
krivera's Avatar
krivera
Default Re: LEAN POP! (red-y)
i hear you!
Old Apr 29, 2004 | 10:45 AM
lead foot 85 vet's Avatar
lead foot 85 vet
I had a carb on a truck plug up and go lean and it popped like a bad distrubuter...had the carb rebuilt and fixed it...also high preformance snowmobil engines will give a lean pop but not like the truck did...I'm trying to understand why a lean mix will pop in the manifold?....I guess a lean mix will burn at a lower temp? thus the open valve during intake is hot enough to lite a fire in the manafold?.........anyway Kevin I know from experiance it can happen.
Old May 15, 2004 | 11:53 AM
da6speed's Avatar
da6speed
2 stroke motors are bad about lean popping. When it is running bad lean, at a high rpm the motor will start popping because it does not have enough fuel with the air intake. A 4 stroke motor would have to be running really lean in order to pop. I have never heard of a 4 stroke motor doing this, have witnessed 2 stroke four-wheeler doing this.
To LEAN POP!
