Diffuser scoop-non functional?
Old Apr 27, 2004 | 01:07 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Diffuser scoop-non functional?
Ecklers sells a diffuser scoop without the entire kit, and the catalog states it is "non functional", however I wonder if this is true...wouldn't the force of the air coming in still increase the pressure of the air going into the intake?
Old Apr 27, 2004 | 04:28 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Re: Diffuser scoop-non functional? (ir0nmaiden420)
Probably not enough to make a difference.
Old Apr 28, 2004 | 09:08 AM
C4SMAJ's Avatar
C4SMAJ
Default Re: Diffuser scoop-non functional? (eschoendorff)
on a 96 when you remove the license plate cover to get the diffuser to fit you have to cut a hole in the bumper....then behind it there is densly packed foam...I have the scoop...and cut a hole in the bumper and thru the foam...I then took a 6" hose and ran it from the rear of the scoop to the bottom of my
air cleander....just cutting a hole in the bumper and sticking the scoop in there will do you no good..the way I have it there is no ram effect or anything but at least there is fresh air getting to the air cleaner....
:seeya
To Diffuser scoop-non functional?
