hypertech power programmer for an LT4
Old Apr 27, 2004 | 11:50 PM
CaliforniaVette's Avatar
CaliforniaVette
Default hypertech power programmer for an LT4
Im considering getting a Hypertech tuner and 180 T-Stat for my LT4. Has anyone used one? were you happy with the results? any other information i should know... thank you
:cheers:
Old Apr 28, 2004 | 01:06 AM
Zix's Avatar
Zix
Default Re: hypertech power programmer for an LT4 (CaliforniaVette)
I'd save your money. The HPP doesn't give anything in terms of performance. It's only good points are the ability to turn the fans on sooner, and adjusting the speedo if you've swapped rear gear ratios...I personally don't think it's worth it for the price. However, if you want one, I have a friend of mine that may one for an LT4...he sold his car and doesn't need it anymore. If you want I can check, at least it'll save you some $$$.
Old Apr 28, 2004 | 01:54 AM
CaliforniaVette
Default Re: hypertech power programmer for an LT4 (Zix)
that would great, if you could email me with the info i would really appriciate it. Thank you :cheers:
Old Apr 28, 2004 | 06:36 AM
95AquaC4's Avatar
95AquaC4
:iagree: As for selling the one your friend has, it is only good to someone if your friend re-uploaded the STOCK program that is stored into the HPP back into his car. If he sold the car with the HPP program still installed, the unit is useless to any other car. :yesnod:
Old Apr 28, 2004 | 12:35 PM
1996blklt4's Avatar
1996blklt4
Default Re: hypertech power programmer for an LT4 (95AquaC4)
Best thing you can do to your car. Get the HPP and use it to turn your fans early together with the HPP 160 degree T-stat. Your car will never reach 190 degrees anymore. I run 165-170 on the freeway and arroung 180 in the city. Best mod :yesnod: :cheers: :cool:
Old Apr 29, 2004 | 01:15 AM
Kblack_LT4's Avatar
Kblack_LT4
I'd be interested regardless of what program is in the programmer. I think I can make it work for what I need. I want the fans on EARLIER as my LT4 runs to damn hot for me. plus I figure the new ones are over priced. Seems anything with the word Vette in it is a lot higher than other cars. But a used one seems like a decent deal, especially since I do not expect performance gains, just changes to the car. So if it doesn't get taken or wanted, contact me. I'd like to get a used one even if it has the old VIN in it. Actually I was hoping Glock or one of the other D/FW guys would speak up on having one. I want to get these changes made. Installing the themostat this week. Thx and best of luck.
Ken :chevy
Old Apr 29, 2004 | 06:41 AM
95AquaC4's Avatar
95AquaC4
Default Re: hypertech power programmer for an LT4 (Kblack_LT4)
Ken :chevy
The unit is VIN coded. If he made ANY changes to his car without changing it back, it is useless. The very first thing the unit does is communicate with the car. It uses the VIN ID to determine a valid vehicle. If it reads a different VIN with someone else's stock program stored, it will not allow ANY changes to your vehicle.
Old Apr 29, 2004 | 09:06 AM
Kblack_LT4's Avatar
Kblack_LT4
Sounds like I should be able to get it cheap then. How much? I'll take care of the VIN thing. Thx. Ken :chevy :flag
Old Apr 29, 2004 | 02:13 PM
95AquaC4's Avatar
95AquaC4
Then your pretty good. Been tried. :yesnod: If your THAT good, you can just build yourself a Power Programmer 4. :D
[Modified by 95AquaC4, 2:33 PM 4/29/2004]
Old Apr 29, 2004 | 02:51 PM
Kblack_LT4's Avatar
Kblack_LT4
I'd rather say I have a possible method to solve this. We have discussed an issue like this for trucks in the past. OK, I stopped right there and called. IT CAN BE done, but at a cost that is to high for what I need. We have sent one in the past and it was 'fixed'. The SN on the unit will determine if and how much it will cost for the 'replacement or trade in' with Hypertech. This unit would run over $200 he said to do this. (It was a LOT LESS in the past) And if one had a good contact at Hypertech, it could be taken care of. Not officially, but it could with the right contacts there. So since this near free fix is gone for me, it's value is greatly deminished to me. I did use to be a code writer (the govt still uses some of my code on some programs they have), but I have ZERO or NO desire to do this anymore. So it is 'not a good value' to me anymore. Best of luck.
Old Apr 29, 2004 | 04:08 PM
NavyVet's Avatar
NavyVet
If the other one doesn't come through, I have a LT4 Power Programmer from the '96 I sold. The stock program was restored - in box w/cables, manual, etc. I used it for early fan turn-on & gears before I built the 383. BTW, I also did back-to-back Dyno runs at Xtreme Motorsports to test the difference. On a stock LT4, it yielded 5.5 RWHP improvement and we waited until the temps were identical. :flag
Old Apr 29, 2004 | 04:26 PM
Kblack_LT4's Avatar
Kblack_LT4
Default Re: hypertech power programmer for an LT4 (NavyVet)
Hey I'm in for this if the price is decent. Please call me or email Kblack@yahoo-inc.com (W) or kblack@geusnet.com (H) 214-782-4290. It'd help me greatly for some minor issues I'm having. Thx Ken
Old Mar 5, 2013 | 06:27 AM
ironital's Avatar
ironital
8th Gear
i have bought 1996 corvette 5.7 l and i want to kn ow if it's lt1 or lt4
how could i know that
Old Mar 5, 2013 | 08:02 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Why would you buy a car without knowing what you are buying?
If everything is factory original:
Automatic transmission = LT1
Manual transmission = LT4
Oh, and......
Old Mar 5, 2013 | 08:10 AM
ironital's Avatar
ironital
8th Gear
Default thanks
yea you are right but it's my first american car
it's automatic transmisiion 5.7l
can i tune it's pcm/ecm via hypertech
or do suggest me other thing
regards
Old Mar 5, 2013 | 10:53 AM
tunedport85inject's Avatar
tunedport85inject
Laptop , obd2 cable connected to aldl diagnostic link , software like tunerpro or datamaster. Sei italiano?
Old Mar 5, 2013 | 12:29 PM
ironital's Avatar
ironital
8th Gear
Default help
are there any other way because i can't use tunerpro
i want adevice no't program
and what is the pin out for usb to obd2 so as to connect my laptop
i have usb 2 serial caple and i have obd2 2 female serial
sorry
regards
To hypertech power programmer for an LT4
Old Mar 5, 2013 | 03:05 PM
Kevin Woods's Avatar
Kevin Woods
1. Look for your SPID Label (a white paper sticker with lots of 3-digit numbers/letters (codes) on it). You can find it on the underside of your trunk lid.
2. Make sure the SPID's VIN number matches the VIN of your car.
3. If the VIN matches, look for the engine option code LT1 or LT4.
That's it .
If you can't find your SPID;
A. Go to a GM Dealership.
B. Give them your VIN and ask them to print out the option codes for your car.
C. Look for the engine option code LT1 or LT4.
That's all there is to it.
KW
Old Mar 5, 2013 | 04:52 PM
Eakster's Avatar
Eakster
Mine came with the car, experimented with it quite a bit and did not notice any improvement. I reverted to the stock tune but with the lower fan settings. So keeping it till I get this motor sorted and a proper tune
Old Mar 7, 2013 | 06:15 AM
ironital's Avatar
ironital
8th Gear
really thanks for your kindness you helpfull man
