sway bar diameter
Old Apr 28, 2004 | 07:08 PM
corvettemaster's Avatar
corvettemaster
Default sway bar diameter
finally got around to purchasing a PST front end rebuilt kit from Power Performance Motorsports. figured since i'm going to have to replace all 4 ball joints on the front, i might as well go ahead and buy the kit to replace all the bushings and tie rod ends too :D should be fun
anyways they needed to know the front sway bar diameter. i looked at mine on my 86 and it looks to be 1". does that sound right for a factory suspension car? it's not a Z51. what size did the Z51 cars come with?
Old Apr 28, 2004 | 07:13 PM
Pete K's Avatar
Pete K
Default Re: sway bar diameter (corvettemaster)
Z-51 had 30mm. I think you have 26mm. Confirm this by slipping a 26mm wrench over bar.
Old Apr 28, 2004 | 07:20 PM
rhneff's Avatar
rhneff
You're correct, the standard FE1 suspension came with a 26mm tubular front sway bar, which is roughly an inch. The Z51 bar for that year was a 30mm solid bar.
Old Apr 28, 2004 | 08:54 PM
c4cruiser's Avatar
c4cruiser
Here's a chart showing suspension information: http://corvetteactioncenter.com/tech/c4/susp_chart.html
Old Apr 29, 2004 | 12:49 AM
Frizlefrak's Avatar
Frizlefrak
Harbor Freight tools sells a digital caliper for around $25. I bought one, and it has come in very handy measuring various things, such as sway bar bushing sizes.
It's always nice to know you are ordering the right parts. :cheers:
To sway bar diameter
