The fun never ends :)
Old Apr 29, 2004 | 03:04 PM
Unriced's Avatar
Unriced
Default The fun never ends :)
After chasing every oil leak known to man, I have a tiny drip
from what appears to be the rear drivers side of the motor.
Intake is recent, along with valve covers and oil pan gasket kit.
Im thinking back of the motor somewhere near dist.
Outside of the intake, where should I start to look?
TIA
Old Apr 29, 2004 | 03:34 PM
Chevy Guy's Avatar
Chevy Guy
Default Re: The fun never ends :) (Unriced)
There isnt to much left. Recheck all your work, look at the oil filter and cooler adapter, rear of the intake, dist. gasket, oil pan etc..etc.... Hopefully it not the rear main seal.
Old Apr 29, 2004 | 03:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Also check the oil temp sensor just above the oil filter. Pull back the rubber connector cover to check for oil.
Old Apr 29, 2004 | 05:09 PM
eric_daniel's Avatar
eric_daniel
Default Re: The fun never ends :) (65Z01)
Oil Pressure Sender!!!!
Old Apr 29, 2004 | 07:46 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Maybe it's just marking its territory! :jester
Old Apr 29, 2004 | 07:51 PM
Unriced's Avatar
Unriced
Default Re: The fun never ends :) (corvetteronw)
Quote: Maybe it's just marking its territory!
__________________________________
Ya....kinda like the Exxon Valdez!!!! :lol:
Old Apr 29, 2004 | 09:58 PM
Pete K's Avatar
Pete K
Default Re: The fun never ends :) (eric_daniel)
Alot of c-4's have the 2 sending units that screw into the tee next to dist. 3 possible leaks in 1 small package. If you pull them to check I like permatex liquid teflon. This stuff has never let me down when sealing threads.
Old Apr 30, 2004 | 02:25 AM
88vettelover's Avatar
88vettelover
Default Re: The fun never ends :) (Pete K)
:iagree: Oil Pressure Sending Units are very often the culprit to tiny oil leaks, or big ones...
To The fun never ends :)
