Corvette VS Heavier car
Old Apr 29, 2004 | 08:42 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Corvette VS Heavier car
Ok, this may be a broad question....I notice alot of cars out there have similar horsepower or even more than my vet, but cannot win the stop light race, I'm assuming because the vet is so light. Is there a formula or a rule of thumb to gauge how much heavier another car with similar horsepower would need to be, in order to lose? Someone had stated in an earlier post that each 100lbs additional weight reduces by 10 HP?
Old Apr 29, 2004 | 08:48 PM
xs650's Avatar
xs650
Default Re: Corvette VS Heavier car (ir0nmaiden420)
Divide the stoplight ready to race weight by the actual horsepower. The result is lbs/hp/ A smaller number is better.
10 lb/hp is only valid if you car has about 10lb/hp
Old Apr 29, 2004 | 10:22 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Our Corvettes enjoy several advantages over some higher-powered cars:
Good weight distribution; higher percentage of weight on the rear wheels.
A good limited-slip differential. Not all of your competition will have one.
Lots of tire. Not many cars have 275/285 rear tires.
What this means is that every Corvette will have the traction to make the most of its power off the line.
Larry
code5coupe
:seeya
Old Apr 29, 2004 | 10:24 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A general rule of thumb for cars in our weight & HP range is that 10chp gain or 100lb reduction is worth 1 mph in the 1/4 mile; here's the formual:
MPH = (HP / weight)^1/3 * 234
where ^1/3 means the cube root.
Expected elapsed time is then given by:
ET = 1357 / mph, approximately
So, you can see that as HP goes up and/or weight goes down MPH increases and ET drops, i.e. the car is quicker and faster in the 1/4 mile.
Plug the above into Excel and you will see exactly how MPH & ET change with weight and CHP.
Of course power band, gears, tranny or converter are very important parameteres not included in the above equations and can make a big difference in results on the street and strip.
Old Apr 29, 2004 | 10:33 PM
Jim Sitton's Avatar
Jim Sitton
Stoplight to stoplight who cares about horsepower. Torque is where its at.
Old Apr 29, 2004 | 11:17 PM
xs650's Avatar
xs650
Default Re: Corvette VS Heavier car (Jim Sitton)
That's why a Peterbuilt trucks beat Corvettes all the time.
And why Harleys beat 600cc sport bikes.
Old Apr 29, 2004 | 11:25 PM
Corvette92's Avatar
Corvette92
Cruising
Default Re: Corvette VS Heavier car (xs650)
The driver has something to do with it too.
Old Apr 30, 2004 | 09:00 AM
loiq's Avatar
loiq
Wow! Peterbuilts beating Corvettes? Harleys beating 600cc sportbikes? What town do you live in?:confused:
[Modified by loiq, 2:01 PM 4/30/2004]
Old Apr 30, 2004 | 10:20 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Corvette VS Heavier car (loiq)
Well, Truck world! Where else? :p: :beatdeadhorse:
Old Apr 30, 2004 | 10:24 AM
Nathan Plemons's Avatar
Nathan Plemons
Very common misconception. Look at ANY dyno graph and you'll see that torque and horsepower cross at 5250 RPM's. That's because they are mathematically related. If you increase torque at a given RPM you increase horsepower at said RPM.
So what you really mean is that PEAK horsepower doesn't matter. You are correct, the car with a higher torque at a given RPM will acclerate faster if everything else is held constant (gears, weight, etc.) BUT the increased torque at said RPM yields an increase in HP at said RPM, there is no way around it.
Old Apr 30, 2004 | 11:08 AM
85blkZ51's Avatar
85blkZ51
I agree with xs650, its the "Power to Weight Ratio" that will give you a good idea of whats going to happen on the street. A 3000lb. race weight with 300hp is a 10 to 1 ratio. 10 hp pushing 1 pound. A 3800lb car would need to make 380hp to do the same thing.
Old Apr 30, 2004 | 11:23 AM
HammerDown's Avatar
HammerDown
Corvettes aren't exactly light. Especially for their size. That has always been one of the major complaints about these cars.
Old Apr 30, 2004 | 11:31 AM
xs650's Avatar
xs650
I take it you haven't been introduced to sarcasm.
[Modified by xs650, 8:33 AM 4/30/2004]
Old Apr 30, 2004 | 11:55 AM
Light84vette's Avatar
Light84vette
Default Re: Corvette VS Heavier car (85blkZ51)
10hp pushing 1lb in a 3000lb race car weight would equal 3,000hp. :lol: You mean 10lbs to 1hp.
Old Apr 30, 2004 | 01:09 PM
PUREC4's Avatar
PUREC4
Default Re: Corvette VS Heavier car (Nathan Plemons)
Ok let's see if I've got this formula
Hp + Torque X $$ + <coficent of drag + $$$ = :party: CHICK'S DIG IT!! :party: :party: :auto: :seeya
Old Apr 30, 2004 | 01:16 PM
85blkZ51's Avatar
85blkZ51
:skep: I guess that explains why I cant balance my checkbook :jester Thanks for the correction
Old Apr 30, 2004 | 01:55 PM
xs650's Avatar
xs650
Default Re: Corvette VS Heavier car (PUREC4)
That's where the old saying, "You can;t beat cubic dollars" came from.
Old Apr 30, 2004 | 02:04 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
:lolg: :lolg: :lolg:
To Corvette VS Heavier car
