Finally wrapping up the 396 project, and we're running into a small issue with cooling the beast at idle. Seems like the water temps will go up to the 230-240 range after about 15 mins of idling. Temps at cruising are in the 180s.
The current cooling/air system is:
Modified TPIS cold air intake with K&N
DeWitts Alum C4 Radiator
Stock Fans
New Stock Water Pump
Is anyone aware of any aftermarket fan setups that could dissipate more heat than the stock units? Any other ideas on how to attack this problem?
I suspect that the problem is not necessarily the water pump as cruising temps are OK, but I'm not sure of the efficency of the water pump at idle when the belts are spinning slower.
Just looking for some additional input to feed back to the tuner.
You could try an electric water pump. They spin at full speed all the time. A friend of mine had an LT1 396 stroker with an electric pump and never had any cooling problems.
The LT1 is set up for an electric water pump easier, but it can still be done.
When are your fans programmed to come on? On my '86 I'm running stock water pump, stock fans and stock radiator. 180deg thermostat and the fans are programmed to come on at 180deg.
Mine comes up to 190deg after a cold start. As soon as the fans come on it quickly cools down to 165. I can make mulitple 1/4 mile runs and sit in the staging lanes with the car idling without temps getting above 170.
What temp are the fans coming on, because you shouldnt still be having cooling problems with that radiator and new WP, despite the fact that the CAI draws air that should run through the radiator.
You could try an electric water pump. They spin at full speed all the time. A friend of mine had an LT1 396 stroker with an electric pump and never had any cooling problems..
I just saw a Meziere add in the latest GM Hi-Tech performance that seemed to advertise the availability of a L98 electric pump. I was not aware that such a unit was available.
I agree. My 415 will idle for extended periods of time with a 195 stat and never gets that hot. I'm using a replacement stock radiator (O'Reilly's Auto Parts), stock main fan and stock water pump too.
I suspect there's something else causing this; perhaps temp that the fan comes on, air in the cooling system; sticking stat; ignition timing; restriction in airflow through the radiator/condensor; etc.
IN my 165 ECM we control the main fan by the ECM and if you have a HD fan, Hypertech makes a FAN ON @ 176 / FAN OFF @ 167 sesnor if I remember right.
Also, I bought a Flow Kooler water pump that flows more at idle to 3000RPM I believe. My 406 does not get above 185 or so.
The FAST system currently has fan control. What I need to find out is whether it's controlling both the main fan + the HD fan, or if it has controls for each of them independently. I was thinking of doing the fan switch option which I know that a lot of other people are using. If it can be done electronically, I would prefer it.
Where did you get that flow cooler pump? If you have the part# handy, that would be great.
I will find out what the fan on/off specs are within the FAST system. I do know that there's a 160 deg thermostat in the car.
I agree that with the Dewitt rad you shuold not have a heating issue,,, and you may have to make sure the rad is burped.
My ECM controls the main fan and my HD fan is controlled by a sensor in the pass-side head. You could have the ECM turn both on if you send the ECM-ON signal to the HD relay as mentioned above.
Jake,
Thanks for the tips. Do you guys think that it's wise to keep the 160 stat in there. I notice that both you and 96LT1 are running 180 or more. Would that help at all in this particular case?
Thanks Larry. Looks like that pump is very affordable as well.
I'm hoping that more of the simple things are covered (burping the rad, mix of coolant/water, stuck stat), but it doesn't hurt to go over all of the bases again.
Thanks to all for your help so far. I will let you know when I find out specifics on the fan on/off temps.
I just checked C-Com (the FAST tuning software) and there was only one fan input. Does you Accel DFI have 2?
Ron
I just checked the CalMap Gen 7+ software and it does control both fans. My current program: 1st fan comes on @ 180 goes off @ 175. 2nd fan comes on @ 195 goes off @ 185.
That Gen 7 is a nice box with a great looking software suite as well. It will be interesting to see what FAST's new system will look like.
Couldn't get in touch with MORE today to ask about the fan on/off temps, but I've got to believe that hopefully the common stuff that was mentioned in this thread has already been checked by those guys. Will let you guys know what I find.
what cam are you running? whats your timing set at at idle? try bumping your timing up to 16*-18* at idle and see if it runs cooler. im betting it will.
Cam is a Crane 222/230 .542/.563 @ 112LSA.
I will also find out about the timing at idle and have them try your suggestion. That could possibly be part of the problem.
Ron[/SNIP]
I've tried three different temp stats: 195, 180 and 160. The 160 keeps the engine too cool, especially during the cooler months; even the 180 doesn't work well for me from, say, Oct through Apr.
So I run a 195 during the cooler months and a 180 during the heat of summer.
