SYS Error... Help
Old Apr 30, 2004 | 04:06 PM
dsg049c's Avatar
dsg049c
Default SYS Error... Help
I keep getting a SYS error while accelerating.. It comes and goes.. I have already checked for error codes.. Everything is OK.. What could be causing the SYS error.. I have been told it could be an electrical error maybe the alternator?
Old Apr 30, 2004 | 04:12 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Default Re: SYS Error... Help (dsg049c)
That's usually the first sign of your battery dying
Old Apr 30, 2004 | 04:14 PM
dsg049c's Avatar
dsg049c
Default Re: SYS Error... Help (Z-07 freak)
I just replaced the battery last year.. Man that was quick
Old Apr 30, 2004 | 04:23 PM
ittlfly's Avatar
ittlfly
Some after market steros can cause the problem also.
Old Apr 30, 2004 | 05:54 PM
kman0066's Avatar
kman0066
Default Re: SYS Error... Help (ittlfly)
Could be caused by a bad ECM or CCM also. Did you check the CCM codes also or just the ECM codes?
Look in the search feature for how to retrieve CCM codes.
Most end up being a bad battery though. In my case, it was a bad ECM causing the batteries to go bad.
To SYS Error... Help
