brake rotors
Old Apr 30, 2004 | 06:20 PM
MXA99FRC's Avatar
MXA99FRC
Default brake rotors
Pending front brake job. Can you upgrade to 13 in. rotors without changing the calipers ?
Old Apr 30, 2004 | 06:31 PM
ittlfly's Avatar
ittlfly
Default Re: brake rotors (Mikes92)
You have to have new mounting brackets which move the caliper futher out to accomodate the larger rotor.
Old Apr 30, 2004 | 06:41 PM
MXA99FRC's Avatar
MXA99FRC
Old Apr 30, 2004 | 06:53 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: For the C5 conversion, you will need a new caliper along with some other stuff :rolleyes: :D
For the J55 package, I am not sure, but if it is the stock 12"caliper and brake pad, what's the point in going to the 13" roter? :confused:
The C5 conversion can be done for less than $ 500 if you shop around (not including wheels or wheel adapters)
The C5 conversion in the front and the DRM proportioning spring to activate the rear brakes is an awesome combination
:seeya
:steering:
Old Apr 30, 2004 | 08:19 PM
VanSpeed's Avatar
VanSpeed
I believe the J55, 13"Ø, brakes are thicker than the 12" Ø brakes. Even though both calipers look the same the J55 is a little wider as a result. So to go to the J55's you would need the mounting brakets, left and right side rotors, and calipers.
Brian
To brake rotors
