LT1 short block difference?
Old Apr 30, 2004 | 08:52 PM
JTHVETTE's Avatar
JTHVETTE
Default LT1 short block difference?
Is a LT1 short block the same from a corvette vs. a Z28 or Trans Am?
Nathan Plemons's Avatar
Nathan Plemons
Default Re: LT1 short block difference? (JTHVETTE)
The Vette LT1 had 4 bolt mains, the F-bodies were 2 bolt. Otherwise they are identical.
Old May 1, 2004 | 01:40 AM
BAM92's Avatar
BAM92
Default Re: LT1 short block difference? (Nathan Plemons)
:iagree: B-bodies also 2 bolt mains.
Old May 1, 2004 | 02:39 AM
kman0066's Avatar
kman0066
Default Re: LT1 short block difference? (BAM92)
Yep, 2 bolt versus 4-bolts mains(Corvette only). We also have 2 knock sensors though the F-body blocks have the ability to add another knock sensor.
If you are thinking of going with one, they are fine. I would suggest going with ARP studs on the mains though(requires align honing at machine shop), or you could go even stronger than the stock 4-bolt mains by getting splayed 4-bolt caps for the 2-bolt block(recommended for over 450hp applications).
OF COURSE, this is all excluding the mini LT1's out there. I guess chevy made some 265 LT1s and these are obviously very different than the 350 LT1 blocks. I think the all went into Impalas and Roadmasters.
Old May 1, 2004 | 06:08 AM
Omega1's Avatar
Omega1
Default Re: LT1 short block difference? (kman0066)
my friend's roadmaster sure ain't got a "mini" LT-1...it's got all 350 cubes under that hood...
Old May 1, 2004 | 01:01 PM
JasonL's Avatar
JasonL
Default Re: LT1 short block difference? (Omega1)
He never said the 350 wasn't available in the B-body :D He is correct, BTW. The 265s went into Roadmaster, Caprice, etc. The Impala SS could only get the 350 though.
To LT1 short block difference?
