Hard to start 88
Old May 1, 2004 | 08:15 PM
HG's Avatar
HG
Default Hard to start 88
When cold, starts OK. After reaching temperatures, it's hard to start. Sometimes takes several trys before starting. Any Ideas before I go to the vette shop and spend more $$$$$$$$ :rant: :banghead:
Old May 1, 2004 | 09:09 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Hard to start 88 (HG)
:cheers: I haven't had the problem yet myself, but many others here have!
Seems like from reading there posts that flooding from a leaking injector(s) is often the problem
When it does finally start, do you see any evidence of "smoke" from the exhaust?
Excess fuel buildup should produce some visible evidence from the exhaust when it does start
:seeya
:steering:
Old May 1, 2004 | 10:00 PM
65Z01's Avatar
65Z01
When warm depress the throttle for a minute of so before starting; if it starts more easily service the injectors.
As a double check, install a fuel pressure gauge onto the Schraeder valve, turn the key On and watch fuel pressure. If it drops off rapidly the chances are very good that a fuel injector is leaking.
Old May 2, 2004 | 10:18 AM
HG's Avatar
HG
Default Re: Hard to start 88 (65Z01)
Thanks, I'll look for the smoke next. I guess it's time for my yearly repair. Last year it was the A/C compressor :banghead: :banghead: :banghead:
Old May 2, 2004 | 10:47 AM
Jloshotz's Avatar
Jloshotz
Default Re: Hard to start 88 (jackdaroofer)
:iagree:
To Hard to start 88
