ADS Super-Chip
Old May 1, 2004 | 10:37 PM
jdenn47's Avatar
jdenn47
Default ADS Super-Chip
Has anyone installed a ADS Super-Chip and does it improve torque-lockup time and improve performance ? I have a 1986 Vette and there is one on E-Bay with a 160 Deg, Thermostat for about $45.
Old May 1, 2004 | 10:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: ADS Super-Chip (jdenn47)
For that money it's worth the expense as the lower operating temp will bring more HP. It will also likely raise the TC lockup point too.
Old May 1, 2004 | 11:04 PM
rsafier's Avatar
rsafier
I had a Thermomaster chip in my 85, got it on ebay for something like 30-40 bucks. Was worth it for the lower operating temps, doesnt do much else. It is nice for the TCC lockup changes. Moves to 42mph.
Old May 2, 2004 | 02:58 AM
BIG JIM 54's Avatar
BIG JIM 54
That's a good price for an ADS chip. I think I paid $75 for mine and I thought I got a deal. CompCams recommended an aftermarket chip with my 501-8 cam.
I did notice an improvement in drivabilty. It just felt crisper. I didn't notice a change in converter lockup. But maybe GM figured the problem out by 1987 and made the necessary changes to the stock chip by then.
But the price is right and I doubt if it will make your engine run worse. It's worth a chance, IMO.
BIG JIM
[Modified by BIG JIM 54, 11:59 PM 5/1/2004]
Old May 2, 2004 | 09:51 AM
jdenn47's Avatar
jdenn47
Well it is on E-Bay and going for over $55. I have seen others in Mid America Designs Magazines for over $200 & Autozone for about the same. If it is worth the price, might be worth bidding on. By the way, where do you install it ? :auto:
Old May 2, 2004 | 03:54 PM
Wheelman's Avatar
Wheelman
Inside the ecm, behind the crash pad on the passenger side
Old May 2, 2004 | 10:12 PM
fixit's Avatar
fixit
Default Re: ADS Super-Chip (Wheelman)
I put one in my '84 and that did make quite a difference across the board, better than the Hyper Tech or Jet.
Old May 2, 2004 | 10:23 PM
tjwong's Avatar
tjwong
Default Re: ADS Super-Chip (fixit)
At least Hypertech will bump the timing across the board so they give you something. But with JET you are lucky that they even do that, I have several JET chips that are nothing but bone stock calibrations with different prom ID numbers.
For true custom proms, contact Jeremy Formato at Fasterproms.com, Ed Wright, Bryan at PCMS4LESS, our own Jesse aka Ski_down_it to name a few. Even I have been known to do a few of them but I specialize in the late model flash PCMs.
Old May 5, 2004 | 08:22 PM
jdenn47's Avatar
jdenn47
Well too late, it sold for $93.
Thanks for the input though. :auto:
To ADS Super-Chip
