Hard start
:smash: I went out to strat the vette to back it from the garage to wash it and it just turned over and wouldnt fir right up,,, I stepped on the gas and it starts. I let off the gas a low idle...WTF.
I took it for a ride and it runs great,,, stop at a stop sign and it is like it wants to stall, but doesnt,,,, what do you all think? IAC ???? :beatdeadhorse:
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
I figured that or a leaking injector,,, I did the test that was on 65Z01 website and no luck,,, but I am steering toward bad or faulty IAC, who stocks these things
:iagree: IAC
You might try http://www.NAPAAUTOPARTS.COM search on idle air valve. I found one there for $32.00
:cheers:
[Modified by RUBYREDVETTECARD, 4:30 PM 5/3/2004]
:cheers:
:iagree:
You can try cleaning the IAC pintle and it's bore but you may need to replace the IAC. After you service the IAC set base idle (method on my site) but you won't need to tweak the TPS as your's isn't adjustable.
:iagree:
I did a complete TB cleaning last month, I did clean the IAC, then reset it correctly. I think it just bit the dust..... I thank you again.......
I Love this Forum
:seeya
I have learned more about cars on this forum then I could ever reading books.....
