radiator drain plug?
Old May 3, 2004 | 12:14 PM
95Redcoupe's Avatar
95Redcoupe
Default radiator drain plug?
Is that a radiator drain plug on the bottom of radiator on pass side? If not is there one i was looking the other day and was tempted to turn it but wasn't sure.
thanks
Rich
Old May 3, 2004 | 12:37 PM
fast not first's Avatar
fast not first
Default Re: radiator drain plug? (95Redcoupe)
The radiator drain plug on a L98 is on the passenger side. Don't know for sure how this is on a LT1.
Old May 3, 2004 | 12:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
On my '88 L98's radiator there is a black plastic drain plug in the inner lower right corner; it is recessed a little and maybe 1 - 1 1/2" in diameter.
After cracking the radiator cap open, turn it CCW and you should see coolant comming out.
Old May 3, 2004 | 12:41 PM
96LT1's Avatar
96LT1
thanks
Rich
Yes it is. (Not much of one if you ask me) :smash: I liked the old ones better, hook a small hose up, open it up and let it drain, no fuss, no mess. I get upset evertime I have to drain the radiator.
To radiator drain plug?
