Problems with distrubutor (90 L98)
Old May 3, 2004 | 04:20 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Default Problems with distrubutor (90 L98)
Or I decided to back down my timing from 10* to 8*. Only problem was that the large cap was against the plenum and couldnt be backed off anymore. So I Rotated the entire disribuitor back. The fireing order is right but it wont run at any less than 12* and it pings like a mother (I could hear the valve clatter through the cover!). However, it idles fine. Theres a little popping out the exahust too.
Any suguestions before I tear it all apart and start over?
Old May 3, 2004 | 04:37 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Default Re: Problems with distrubutor (Firevette)
Nevermind,.... I fixed it. :banghead:
It pays to step back, get a drink, and look at the big picture. :bb
Old May 3, 2004 | 04:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the wires in the front of the dist are pointed at the middle of the intake base you should be fine so long as you get the rotor pointed right.
Old May 3, 2004 | 09:50 PM
Sam Lam's Avatar
Sam Lam
Well..........aren't you going to tell us what you found? Most of us ole dudes have "been there and done it" too!
SAM
To Problems with distrubutor (90 L98)
