optispark install question
Old May 3, 2004 | 09:50 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default optispark install question
When installing a 2nd generation (95-up) optispark, should you put some oil or something around the big seal on the timing cover?
Old May 3, 2004 | 09:55 PM
RichS's Avatar
RichS
Default Re: optispark install question (POLOVETTE 94)
Felpro gaskets say to install it dry and only lube the crank seal.
Old May 4, 2004 | 12:27 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: optispark install question (RichS)
:iagree: It's probably Teflon like the rear crank seal and should be installed dry.
Old May 9, 2004 | 12:22 PM
POLOVETTE 94
So no oil on the inner edge of the seal (the part at the opti, not the outside, at the timing cover)? I know you should lube the inside of the crank seal, where the hub touches. :confused:
To optispark install question
