Planning on replacing my shocks soon for the first time. About how long would it take to replace all 4? Doesn't look like I need to take the wheels off the fronts but might have to on the rears. Any advice is appreciated.
I've always removed the wheels, not like there is a ton of room, I suppose you could do without, but how long does it take to remove a wheel (2 minutes?).
I just did all 4, took me about 2 hours total, and was by no means rushing. Probably 1 hour if your in a rush.
I never loctited my bolts, but that is a pretty good idea, better safe then sorry.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Re: Shock question (jabez)
Takes me about 4 hours, but I am compelled to clean wheelwells, suspension components, wheels, etc. while I'm in there.
That means pulling all four wheels off, and you don't need to pull the fronts to R&R shocks. You should allot about 2 hours, I'd estimate.
