Rear view mirror vibration?
Old May 4, 2004 | 11:46 AM
95AquaC4's Avatar
95AquaC4
Default Rear view mirror vibration?
Mine vibrates and distorts the image pretty badly. Anyone else's does this? I haven't looked yet, but I assume there are mounting screws that may be loose?
Old May 4, 2004 | 11:53 AM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: Rear view mirror vibration? (95AquaC4)
There are mounting screws,,, mine did the same thing and feel off :eek:
I just tightened it back up
Old May 4, 2004 | 12:28 PM
FSTRNU's Avatar
FSTRNU
Mine does the same thing when I have the top out. I dont remember noticing it with the top in but then again I never have the top in.
Old May 4, 2004 | 12:40 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Rear view mirror vibration? (FSTRNU)
I just got new wheels. Poof! vibration problem fixed!! Guess a couple were bent huh? :lol:
Old May 4, 2004 | 01:17 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Mine did the same thing and I would tighten it and a few days later it would be loose again. Use some Loc tite on the screws.
Old May 4, 2004 | 01:25 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Rear view mirror vibration? (joecaver)
That's what I used. Works like a charm. :yesnod:
Old May 4, 2004 | 02:11 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Rear view mirror vibration? (Steel Blue 91)
OR, jaut a little piece of the white teflon tape you use for threaded connections worls great and easier to remove than loctite
:seeya
:steering:
Old May 4, 2004 | 03:00 PM
65Z01's Avatar
65Z01
That was the problem with mine when it vibrated.
Old May 4, 2004 | 06:32 PM
jabez's Avatar
jabez
Default Re: Rear view mirror vibration? (65Z01)
This happen to me last week. One turn of a phillips screw driver should do the trick. Maybe add teflon tape to screw so it won't vibrate loose again. :auto:
Old May 4, 2004 | 06:44 PM
vetteseniorcit's Avatar
vetteseniorcit
Out of balance tires and wheels will make that sucker dance! Good indicator that you need re-balancing.
Old May 5, 2004 | 06:42 AM
95AquaC4's Avatar
95AquaC4
Default Re: Rear view mirror vibration? (vetteseniorcit)
hmmm. seems easier to simply tighten the screws!! :lol: Seriously, thanks for the info, I'll look at both the mounting of the mirror itself, and any other possible causes.
Old May 5, 2004 | 07:55 AM
Red Tornado's Avatar
Red Tornado
i agree, this could be a contributing factor. i had two bent wheels, it didn't really cause vibration to the mirror, but it sure raised some he** in the rear....sent 'em out for repair, and now they're 100% better :cheers:
p.s. stock aluminum alloy corvette wheels are entirely subject to bending on even small potholes :mad
[Modified by bradvette, 7:55 AM 5/5/2004]
Old May 5, 2004 | 11:32 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Mine did the same thing. I took out the screw and put in a new one, tightened it VERY tight.
Problem solved! :auto:
Old May 5, 2004 | 11:36 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Simplest solution=turn the volume down on the radio, even my hair vibrates from the stereo.
To Rear view mirror vibration?
