dash lights 87 vette
Old May 5, 2004 | 07:45 PM
BILL88's Avatar
BILL88
Default dash lights 87 vette
my friend has a problem with dash lights. when he starts the car they are nice and bright, after five minutes they go dim,as if he turned the light switch to the lowest position.
turn the switch to full position and they still stay dim. it happens day or night.
thanks,
bill
Old May 5, 2004 | 07:50 PM
vader86's Avatar
vader86
Default Re: dash lights 87 vette (BILL88)
That sounds like either a light sensor problem or that the bulbs need replacing, I can see how it'd be either or.
His bulbs probably need replacing anyway, there are 4 of them, and they are Sylvania 882.
Old May 5, 2004 | 11:14 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Same condition here.
Is there a test to determine if it's the sensor?
Old May 5, 2004 | 11:25 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Re: dash lights 87 vette (Vett-eight-nine)
As I recall, the display is brighter during the day to prevent reduced visibilty from glare. At night if you shine a flashlight on it the display should get brighter(or vice versa, place your finger over the sensor in the day and see if it dims) the sensor is the square hole on the upper left hand corner of the display.
To dash lights 87 vette
