Increase speed without increasing HP?
Old May 5, 2004 | 11:47 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Increase speed without increasing HP?
What are some ways to increase speed without adding more HP (like weigh reduction or better aerodynamics)
what about increasing torque?
Old May 6, 2004 | 12:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Increase speed without increasing HP? (ir0nmaiden420)
Are you inerested in top speed or acceleration?
Old May 6, 2004 | 12:14 AM
vader86's Avatar
vader86
increasing torque usually brings with it more HP, though if you mean increasing torque at a certain low/mid rpm then you can lose some top end HP as a result
and HP is where the speed comes from in the 1/4mi
I dont understand your question
Old May 6, 2004 | 12:19 AM
ir0nmaiden420
increasing acceleration
zelement's Avatar
zelement
Easy. Reduce weight.
Old May 6, 2004 | 12:24 AM
vader86's Avatar
vader86
weight, gears, higher stall TC for auto
almost anything else you do is going to move that power peak up in the band
Old May 6, 2004 | 12:26 AM
65Z01's Avatar
65Z01
Ah then, I agree; reduce weight. For example leave the spare & jack home and stomp on it with 1/4 tank of fuel in the tank.
Also more gears will increase acceleration, to a point. Of course you still have to hook it up.
Old May 6, 2004 | 04:01 AM
BIG JIM 54's Avatar
BIG JIM 54
Since the formula for horsepower is HP=RPMxToque/5252, you cannot gain torque without increasing horsepower unless and equivalent loss in RPM happens that would compensate.
Also, vehicle weight has little to do with top speed but it has a tremendous effect on acceleration. 100 pounds equal about .1 sec in the quarter mile.
BIG JIM
Old May 6, 2004 | 06:43 AM
95AquaC4's Avatar
95AquaC4
reducing weight as said above. Good rubber, maybe even DR's(I run mine on the street)gears will help, but you'll reduce top end...there may be more,someone else will be along soon.
Old May 6, 2004 | 10:51 AM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Default Re: Increase speed without increasing HP? (95AquaC4)
Reduce weight.
I removed front sway bar, A/C and pulleys, and stock seats.
My Racing seat weigh 15 lbs ea.
Skinnies up front will result in a loss of about 30 lbs per tire/ wheel.
Go on a diet! (costs less).
Better rubber in rear helps on lighter (racing) wheels.
These, along with all the above suggestions should help!
Matt383
Old May 6, 2004 | 10:55 AM
scorp508's Avatar
scorp508
Default Re: Increase speed without increasing HP? (Matt383)
Lexan windows, carbon fiber body panels & shafts. :jester
Old May 6, 2004 | 11:07 AM
Matt383's Avatar
Matt383
Default Re: Increase speed without increasing HP? (scorp508)
I'm sure some people think it may be wierd, but you're right about that carbon fiber body parts. but $$$$$$$!!
Old May 6, 2004 | 11:09 AM
lead foot 85 vet's Avatar
lead foot 85 vet
Driving down hill works for me :D
Old May 6, 2004 | 11:31 AM
aeronautica86's Avatar
aeronautica86
lowering the car's front end will help a little bit (lowers the drag coefficient)
Old May 6, 2004 | 05:07 PM
C10 JDR's Avatar
C10 JDR
Default Re: Increase speed without increasing HP? (aeronautica86)
Could be wrong here, but if you want to increase top speed, I think you need to gain weight, not reduce it. Take you longer and further to get there though.
Old May 6, 2004 | 05:17 PM
Matt383's Avatar
Matt383
Default Re: Increase speed without increasing HP? (britvette)
I think we are talking 1/4 mile times and speed here if am not mistaken.
So making the 1/4 mile further would be a problem. :)
Old May 6, 2004 | 06:09 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Most things won't increase your speed, but will increase your E/T.. which is more important IMO. Start with a rear end ratio that maximizes your engine's power band.
Old May 6, 2004 | 06:27 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Re: Increase speed without increasing HP? (lead foot 85 vet)
Yeah, also try putting some stickers on your car. I see a lot of guys doing it, so it must work! Oh... "Type-R" is good for at least .2 in the 1/4. :D
(i'm sorry... i couldn't resist)
[Modified by eschoendorff, 11:28 PM 5/6/2004]
To Increase speed without increasing HP?
