Heater/AC Here we go again!!!
I did a search through the forums on this. I found a few bits and pieces of information, but nothing rock solid. Ok here's what I got:
When I turn my A/C on, it will work, then turn hot. So, I removed the blower control module unit under the hood, on the passenger side. Looked in there and had my g/f turn on the air. The door didn't move. I stuck a screwdriver in, and it moved freely.
So I read that there's a plastic retaining clip on the rod thats on the door.
So, at work, I removed the shroud (pain in the butt by the way) and saw that there was a white plastic clip on the top on the rod.
Is there another retaining clip underneath?
Is this that big of a job, removing the dash components under the passenger side?
If so, I think I might replace the heater core while I'm tearing all that out just because of the horror stories I've heard.
It reached 90 here today, and I can't take sporadic air conditioning!! Any and all feedback/information is going to be helpful. Thanks in advance! :cheers:
Few more bits of info. This is an 88 with the Digital Controls, and the temperature setting has been flicking on an off for some time. Once, again any help would be greatly appreciated!
[Modified by 88vettelover, 1:30 AM 5/7/2004]
When I drive, I think the door is moving with every bump I hit, you know, it just moves on its own. I'll check for faults today and post what I find.
Thank you all! :cheers:
SunCr: I also couldn't get the codes? I pressed ext. temp and auto at the same time. And it came up with -01 and then I hit warm until it went to -08 and then pressed warm again and it just kept cycling through the numbers -1 through -09???? :confused:
The door I'm talking about, that isn't moving at all is the door thats located in the evaporator housing. If I remove the little controller, and watch the door, it doesn't move when I change it from heat to A/C.
But, if I turn on the A/C and reach in there with a screwdriver, and open the door, I get blazing hot heat. If I shut the door, the A/C blows cold as ice.
So what controls this door? Vacuum?
Here's some pictures: http://www.cardomain.com/id/88vettelover - the first picture in the sequence is the door under the dash, that one is functioning properly, the next one in the sequence is the shroud where the other door is located, the third one is the picture of the evaporator with the door right next to it, kinda rusty in the picture.
Thanks!
:banghead: :banghead:
On the codes, after you advance it to 08 with the warm button, hit the cold button - that will display any codes.
How do I go about testing the rod? I see that theres a 7mm screw above the harness and then the harness itself.
Do I have to drop that plastic panel down?
Maybe I'm thinking the hush panel is the one with the interior light attached to it...is that not the hush panel?
If so, I already began removing that plastic panel once, but it didn't want to come out. Maybe I'm missing something here.
Thanks for the help so far.. :)
EDIT: I just went and checked for codes, but none there. Hit ext. temp and auto at the same time, scrolled to -08 and hit cold. 00 showed up.
[Modified by 88vettelover, 11:03 PM 5/7/2004]
I don't understand how I could see the motor working? All I see under there is plastic and more plastic.
SunCr: I've been trying to send you some IM's, do you have them disabled? I think it would be easier to communicate that way.
Thanks for the help!
:banghead:
The harness runs from the Programmer, which is above the accelerator, over to the motor. It's plugged into the motor.
[Modified by SunCr, 8:57 AM 5/8/2004]
I'll snap some pictures and post them in a few.
SunCr if you're online send me an IM. Thanks! :cheers:
I know it's that door in the shroud, I just am not sure how to go about getting to the linkage.
Ok, let me review, SunCr, I found the harness you were talking about with the correct wiring. I'm assuming this is exactly where the motor is. But there is a huge plastic peice that is under there and I can't see anything around it. I see a screw above the harness, but that's the extent of it. I'm gonna go look right now as I'm posting this and see if I can see anything else.
BRB....
Ok, I can see the harness, that's it. I have a picture of it, but you can't really see anything else around it. The harness I'm talking about with the exact same wires you told me is plugged into the black plastic peice that is right next to the duct that runs from the passenger side to the driver side.
Is this right?
I only saw one screw by that harness.
For pictures go here: http://www.cardomain.com/id/88vettelover
There's a picture of the harness I'm referring too.
:banghead: :banghead: :banghead: :banghead:
Thanks for all your help. I'll post my results! :banghead:
