Service ASR
Old May 7, 2004 | 12:14 PM
rcolling's Avatar
rcolling
Default Service ASR
I know this has been talked about several times but I am about to spend around $1,100 to try and get this fixed and want to make one last check.
When I bought my car several years ago the Service ASR light was on. Every now and then it goes off but it is mostly on.
Pulling codes you get a 72. Serial Data Link Error.
This essentially means that the ECM cannot talk to the ABS control Unit.
AntiLock brakes work
The serial link is one wire. My normal mechanic even tried running a new wire from the control unit back to the ECM. No luck
Several mechanics have looked at it and nobody, including talking to Gordon Killebrew, is willing to say that changing the ABS control unit will fix it.
This part is expensive, almost $700.
Anybody else have this problem or have had it fixed?
Old May 11, 2004 | 03:13 PM
rcolling's Avatar
rcolling
Default Re: Service ASR (rcolling)
Nobody has ASR problems???
I found the part at Vette2Vete.
So the cost is now $125 shipped to my front door!
Ordered it today.
