Fan problem
Old May 7, 2004 | 11:52 PM
FD2BLK's Avatar
FD2BLK
Default Fan problem
My fans wont come on unless the AC is on could this be a bad relay? I haven't had a chance to look at it yet but I noticed the car zooming past 235 degrees so I looked at my fans just sitting there and cut the AC on then bang they where running. I thought I would post here first and see what you guys think before I break out the meter tomorrow and start chasing wires.
Thanks in advance, :cheers:
Old May 8, 2004 | 12:04 AM
88vettelover's Avatar
88vettelover
Default Re: Fan problem (84LT1)
Had the same problem with mine, and it was suggested to me to install a new t-stat. I put a new one in and bam, fans came back on.
Old May 8, 2004 | 11:51 AM
FD2BLK's Avatar
FD2BLK
Default Re: Fan problem (88vettelover)
I don't doubt you but what would a new stat have to do with the fans :confused:
They are cheap enough so I may pick one up today but I just cant see how a T-stat would stop the fans from working. My car runs at 200 deg's as long as the A/C is on and it was 90 degrees yesterday and that was also in traffic.
Old May 8, 2004 | 12:25 PM
rick lambert's Avatar
rick lambert
The fan is ECM controlled with the AC on. Have you tested your fan relay or the thermo switch-it's a fairly easy test.With the key on ground the temp. switch-if the fan comes on now it's a faulty switch. To check relay-located in front of battery on wheel well-jump terminal A black/red wire to terminal E red wire, if the fan now comes on the relay is faulty. ;)
Old May 8, 2004 | 01:41 PM
CFI-EFI's Avatar
CFI-EFI
The fan(s) are NOT ECM controlled on an '84. The main fan comes on when activated by the temp switch in the right head between the #6 and #8 spark plugs. Since this is an engine conversion and likely an ECM conversion, too, one can only guess how the fans are wired.
A thermostat change will have NO effect on fan operation.
RACE ON!!!
Old May 8, 2004 | 02:14 PM
FD2BLK's Avatar
FD2BLK
Default Re: Fan problem (CFI-EFI)
The fan(s) are NOT ECM controlled on an '84. .
RACE ON!!!
My Bad, Its a 94 not an 84, I haven't goten around to changing my sig since I got the new car. I just installed a temp switch in the head (Kind of like the 84) so the fans will come on at 180 no matter what. I replaced both of the old fan relays with no joy so I said to hell with it and installed the switch
Old May 8, 2004 | 09:30 PM
CFI-EFI's Avatar
CFI-EFI
:shocked: :banghead: :banghead: :banghead:
To Fan problem
