AC on - off continually
Old May 8, 2004 | 09:22 PM
mr96's Avatar
mr96
Default AC on - off continually
does anyone have an idea what would make the AC turn on and then off almost immediately. just checked it and it will not stay on. lifted the hood and can hear it turn on then off. it worked great before storage.
any help would be appreciated.
thanks
:cheers:
Old May 8, 2004 | 09:26 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: AC on - off continually (mr96)
defective pressure switch?
Old May 8, 2004 | 09:30 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Most likely some of the charge leaked out during storage. Your low pressure switch is sensing this and shuts off the compressor
Old May 8, 2004 | 10:44 PM
1996blklt4's Avatar
1996blklt4
Default Re: AC on - off continually (flyersfan1088)
Low freon ! time to recharge ! :cheers: :cool:
Old May 8, 2004 | 11:04 PM
86Moon's Avatar
86Moon
Default Re: AC on - off continually (1996blklt4)
:iagree: Get some dye thrown in there and see where it may be leaking at :seeya
Old May 9, 2004 | 09:22 AM
mr96's Avatar
mr96
Default Re: AC on - off continually (86Moon)
before i went to the 50th last year it was charged and they said they put dye in with it to see if it would leak (forgot about them doing that). now i need to start looking for the leak.
:eek:
thanks for the help!!!
:smash:
Old May 9, 2004 | 09:40 AM
BigTodd's Avatar
BigTodd
Yup, sound like low on Freon. If you watch your compressor click on and off that is a classic symptom. Also you might see your freon lines freezing up or are really cold to the touch. Mine actually had frost on it when I rased up the hood. Got a shot of R12 and fixed the problem.
Might also be high head pressure from a clogged orifice. That would be a bigger pain, cause you have to evacuate the system and clean it. :)
Old May 9, 2004 | 12:33 PM
SunCr's Avatar
SunCr
Default Re: AC on - off continually (BigTodd)
'96 is R134. There should be a code, anything from P530 to P534 for low charge. I believe Autozone can scan it for you.
Old May 9, 2004 | 02:18 PM
mr96's Avatar
mr96
Default Re: AC on - off continually (SunCr)
thank you for the advice. i did not know autozone could help me out with that. they will be seeing me soon.
:cheers:
To AC on - off continually
