take a look at this cam
Old May 9, 2004 | 08:13 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default take a look at this cam
lobe separation 109.3
valve overlap -30.5 crank degree
centerline int 105.3 atdc /exh 113.3 btdc,
duration int 181.8 crank degree/exh 194.2,
peak cam lift int .233/exh .255,
peak valve lift int .362/.373exh,
lift at tdc int .0199/.0198 exh.
dur at .050 int. 181.8/exh .194.2
what would this cam do in a 5.7. what is this cam set up for? The 109.3 lobe sepation is quite low possible giving a rough idle but being the lift numbers are low maybe not. What do you all think about this cam and what would it be good for?
[Modified by vert2go89, 8:12 PM 5/9/2004]
Old May 9, 2004 | 08:58 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: take a look at this cam (vert2go89)
Waaay too many extraneous numbers jumbled in there to make any sense of. What *I* noticed was, " valve overlap -30.5 crank degree ". Is that, negative 30 1/2 degrees??? If it really refers to 30* of overlap, then "lope" won't be a problem Good luck, and...
RACE ON!!!
Old May 9, 2004 | 10:05 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
That cam would be good for nothing in a 350. Less than .400 lift?!?! That sounds like a 4 cylinder cam.
Old May 9, 2004 | 10:13 PM
JAKE's Avatar
JAKE
If that 181.8 is the .050 number, then it's a very, very short duration camshaft. A lot shorter than even the stock TPI camshaft.
I suspect it is for something like a 305 - Three-Oh-Five - or maybe even something smaller in displacement, like a 283 or, what was the other little guy, a 262.
You can post your question on the ThirdGen.org board because some of those guys have Three-Oh-Five engines in their 'F' bodies.
Jake
Old May 9, 2004 | 10:19 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: take a look at this cam (JAKE)
I think there was a 262, 20 or so years ago. The original "mouse" was a 265.
RACE ON!!!
Old May 10, 2004 | 12:07 PM
C10 JDR's Avatar
C10 JDR
Default Re: take a look at this cam (CFI-EFI)
Definitely way wimpy even for a 305, I have an ex 1980 350 Corvette cam in a 305, (low 200's @ .050 ?), and that doesn't feel big or lumpy at all.
Could you weld it to an old rotor and make a desk lamp out of it or something :confused:
Old May 10, 2004 | 07:53 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: take a look at this cam (britvette)
That's exactly what I thought about it but the 109.3 had me confused. A cam with higher number like a 112 or 116 would be more of a radical cam? PS it would make an ugly lamb even.
Old May 10, 2004 | 11:36 PM
Dominic Sorresso's Avatar
Dominic Sorresso
Waste of time cam. As a comparison here's some of the specs from a cam I just installed in a 350:
269/269 @ .006
.528/.528 lift with 1.6 lifters
Lobe centerline is 110 with a 4d Advance
Old May 11, 2004 | 12:09 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: take a look at this cam (Dominic Sorresso)
269/269 @ .006
So what does that make the lobe centerline, without the advance?
RACE ON!!!
Old May 11, 2004 | 01:41 PM
Dominic Sorresso
CFI,
The lobe centerline is 106 WITH the advance. 110 without. Sorry I didn't clarify that.
Old May 11, 2004 | 08:41 PM
CFI-EFI's Avatar
CFI-EFI
OK, I got you. That is the intake lobe centerline, installed, and not the LSA. I'm with you.
RACE ON!!!
Old May 11, 2004 | 10:37 PM
Dominic Sorresso
LSA or LCA is 108
To take a look at this cam
