90 L98 idle setting
Old May 10, 2004 | 01:17 AM
psuvette's Avatar
psuvette
Default 90 L98 idle setting
i've read through the idle setting procedure in the tech section, but there seems to be an inconsistency. when setting the base idle, some resources say to leave the EST wire connected, while others say to disconnect it. also, does everyone with a manual try to go for a 450 idle in neutral? or do you aim a bit higher so that the iac has to work less and maybe have smoother airflow for a smoother idle?
Old May 10, 2004 | 05:10 AM
86PACER's Avatar
86PACER
Default Re: 90 L98 idle setting (psuvette)
The Shop Manual highlights this step in bold lettering as "importaint"
Old May 10, 2004 | 08:57 AM
Crispyc21's Avatar
Crispyc21
Default Re: 90 L98 idle setting (86PACER)
Soooooo, does that mean to disconnect or leave it connected???
Old May 10, 2004 | 09:19 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: 90 L98 idle setting (Crispyc21)
Disconnected :yesnod:
Old May 10, 2004 | 09:31 AM
Crispyc21's Avatar
Crispyc21
Default Re: 90 L98 idle setting (AGENT 86)
Damit, I did mine connected.
Old May 10, 2004 | 11:59 AM
psuvette's Avatar
psuvette
thanks!
Old May 10, 2004 | 03:17 PM
86PACER's Avatar
86PACER
Disconnected durring the procedure.
To 90 L98 idle setting
