Injector size.
Old May 10, 2004 | 07:50 AM
devilfish's Avatar
devilfish
Default Injector size.
My goal is around 420/430 FW hp. Time to get bigger injectors?
Old May 11, 2004 | 11:42 AM
Aaron's 87's Avatar
Aaron's 87
Default Re: Injector size. (devilfish)
People get 24's to work at that power level. 30's might be safer. Lots of opinions out there. Do a search.
Old May 11, 2004 | 03:04 PM
devilfish's Avatar
devilfish
Default Re: Injector size. (Aaron's 87)
what does my vetteg or stock??
Old May 11, 2004 | 03:59 PM
Bluevette85's Avatar
Bluevette85
I think you have 22 lb injectors. Only 85's had 24 lb stock.
Old May 14, 2004 | 01:34 AM
new'92's Avatar
new'92
Go to this site, http://www.racesystems.com, and download the performance calculator. It's free and will tell you what injectors you need for whatever horsepower your looking for.
Old May 15, 2004 | 02:21 AM
ol,RJ's Avatar
ol,RJ
try your stock injectors first.
I know 24lb injectors will handle 420fwhp (easily) and you may be able to do it with 22lb injectors as well. all you need is a good fuel pump (walbro) and an adjustable fuel pressure regulator (good things to have no matter what injector you run).
if they work you'll save money and have better idle/drivability than big injectors would do.
if they can't flow enough then get a set of 26lb injectors.
I'm running accel 30lb'ers and making 475fwhp and I think 26lb injectors would have been better for me.
BTW, I just looked at your sig and saw that your running a ported TPI intake so I would try the stock injectors for sure. since your not going to be running past 6000rpm the duty cycle won't be as big a deal. as rpms increase the available time to fire injectors gets shorter, that when big injectors help most.
[Modified by ol,RJ, 1:31 AM 5/15/2004]
Old May 16, 2004 | 09:15 AM
devilfish's Avatar
devilfish
Default Re: Injector size. (ol,RJ)
Hi
My sign isent updated.
Im going to run this
LT1 intake
HOT CAM kit
AFR heads 195
hooker headers
Old May 16, 2004 | 03:13 PM
ol,RJ's Avatar
ol,RJ
ah thats a different story then.
the hot cam and LT1 intake will rev higher than a TPI intake.
so I doubt the stock 22lb injectors will work at WOT 6000rpm, but since the injectors on a LT1 intake are pretty easy to change it would be worth trying them. all you'll be out is a little time tuning.
If your expected flywheel HP numbers are acurate, 24lb injectors will handle it (with higher fuel pressure if needed).
I wouldn't go any higher than 26lb injectors though.
the real problem with bigger injectors is idle/low rpms, its hard to get them lean enough. add a big cam that makes less vaccume at idle and that affects the fuel pressure (less vaccume on the fuel pressure regulator at idle = more fuel pressure at idle) making it richer too.
so for street driven cars its best to use the smallest injector that is still able to do the job.
[Modified by ol,RJ, 2:20 PM 5/16/2004]
To Injector size.
