bad plug wire?
Old May 10, 2004 | 10:07 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default bad plug wire?
Is there anything that can give the symptoms of a bad plug wire(s) besides a bad wire? Under light acceleration, it runs fine. Anything over 40-50% throttle and it starts cutting out and sounding like an outboard motor. I know I burned at least 2 wires on the manifold after the new intake went on, and I replaced those. I don't have an ohmeter, so testing them is out of the question. I know it wouldn't hurt to replace the rest, but I want to rule out any other possibilities before I start throwing money at something I may not necessarily need. Thanks
Old May 11, 2004 | 12:21 AM
JAKE's Avatar
JAKE
Default Re: bad plug wire? (flyersfan1088)
". . . throwing money at . . ." That's exactly what you're going to end up doing without the proper tools.
It's just 'the cost of doing business' when you plan on working on these engines yourself.
Buy a digital ohm meter; I saw an inexpensive one at ACE hardware on one of their tool tables.
Think about how much it's going to cost you to pay someone else to diagnose the problem (bet he'll have the right tools) and after you pay the bill, you still won't have the tools to be used the next time something like this comes up.
Just my thoughts.
Jake
Jake
Old May 11, 2004 | 12:45 AM
Bluevette85's Avatar
Bluevette85
Cracked distributor cover? Failing ignition coil?
Old May 11, 2004 | 01:26 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Even if the wires ohm out ok there could be a problem with the insulation.
I agree, check the dist cap as well as the wires; at night spray a light mist onto the wires and watch for corona discharge.
Old May 11, 2004 | 05:15 AM
flyersfan1088
Default Re: bad plug wire? (JAKE)
[QUOTEIt's just 'the cost of doing business' when you plan on working on these engines yourself.
[/QUOTE]
Won't cost me a dime to use my Dads ohm meter, just didn't want to drive across town to get it. I was tired last night when I posted the question. Plug wires seemed obvious to me, but thought that maybe I was overlooking something obvious since I was tired.
[Modified by flyersfan1088, 4:16 AM 5/11/2004]
Old May 11, 2004 | 07:30 AM
vetteseniorcit's Avatar
vetteseniorcit
An oil-fouled or carboned plug is a good indicator of a bad ignition wire. A lot of folks can't believe it, but it's easy to wipe out a plug wire when handling one. Especially if it's got any age on it
To bad plug wire?
