My 87 Vette has Hooker long tubes,hi-flow cat,Flowmasters,adjustable fuel reg,mod maf,Lingenfelter intake base,ASM large tube runners,ported plenum,52mm tb, TPIS stage 3 chip,160 stat,SLP cold air insuction, 1.6 roller rockers and 3.54 gears. The car started off with 240 HP.How many HP is all this bolt on stuff worth collectivly? By the way,How much more HP woulf I get if I added a Lingenfelter cam and ported the heads?
Thanks :D
Re: How many HP is this stuff worth? (james holley)
I am wondering if the Hooker long tube headers will actually help your setup because of your engine rpm range...I think smaller headers might be better and they could enhance your torque.
the only way to really find out what your car is putting out is to take it to the dyno, have them run a couple of times and see the results, it is not only what you got in the motor, it is also the way it's combined.
hopefully you have some facility close to home where you can do that, it is very reasonable normally 50 to 70 bucks, and you can see right there the result of your mods, besides most of this places can also advice you as to what steps to take next ect. ist's wellspent money
