Low coolant problem solved -- Finally!
Old May 11, 2004 | 01:21 AM
K87ZZ4's Avatar
K87ZZ4
Default Low coolant problem solved -- Finally!
I've spent months trying to find the real source of this problem and I think I've finally got it fixed. What was happening was that the low coolant light would come on intermittently, yet when I would check the coolant level after it cooled off, it was OK. I "packed" it a few times, but the light would come on after driving it a while. It would never overheat, though. I found a heater hose connection that seemed loose, but no change. All was well, as far as the coolant level when cold and the temp while running... it was just that the light kept coming on. It seemed like the sensor was working properly, though.
Finally, one day I could smell coolant after driving a while and popped the hood... I could see just a bit of coolant on the manifold near the thermostat housing... the engine hadn't gotten so hot as to burn it off, yet. So, I replaced the gasket and sealed it up, good.
The reason I even mention all this is that it was tough to find because the coolant would get boiled off when the engine got good and hot, making for very little evidence of a leak. It would only leak when they cooling system built up enough pressure, and the leak was a one of the highest points in the system, so not much coolant was ever lost (just enough for the light to come on from time to time). I would "pack" the system by adding water just after the thermostat opened, and within 5 miles, the low coolant light would be on again; yet, I couldn't spot the leak.
Anyway, in hopes of this helping someone else discover the solution to a similar problem... :cheers:
Old May 11, 2004 | 01:24 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: Low coolant problem solved -- Finally! (K87ZZ4)
:cheers:
Thanks for the "heads up."
Old May 11, 2004 | 04:27 AM
69mako's Avatar
69mako
Default Re: Low coolant problem solved -- Finally! (joeveto)
:cheers:
:withstupid: :yesnod:
Old May 11, 2004 | 10:47 AM
rick lambert's Avatar
rick lambert
Default Re: Low coolant problem solved -- Finally! (69mako)
:iagree: me to thanks-wish everyone would post the fixed :thumbs:
Old May 11, 2004 | 10:48 PM
jfb's Avatar
jfb
Awhile back I was very slowly losing coolant and could never find the leak. One day I opened the hood after driving home and saw a drop of coolant fall on the left exhaust pipe and disappear in a puff of steam. New head gasket fixed it!
Old May 12, 2004 | 12:33 AM
McShagger's Avatar
McShagger
Wow, how did you spot that one? Great job bro.
Old May 16, 2004 | 04:26 PM
dand1892's Avatar
dand1892
yea i think mine started doin this i'll check
To Low coolant problem solved -- Finally!
