Early opti replacement...
Old May 11, 2004 | 02:07 AM
JJ 86's Avatar
JJ 86
Default Early opti replacement...
How difficult is it to replace the opti and water pump on a 92 coupe? Is it better to go gm or aftermarket for both? How long should it take to replace them? :smash:
Old May 12, 2004 | 11:23 AM
corvette1271's Avatar
corvette1271
Default Re: Early opti replacement... (JJ 86)
...go to search and type in corvette1271......i just had a dsicussion on that topic myself...... :cheers:
Old May 12, 2004 | 11:24 AM
Nathan Plemons's Avatar
Nathan Plemons
If you've never done it before, it'll take you all day. If you've done it before you can do it in 2 hours, including time to scrape off the old water pump gasket.
To Early opti replacement...
