what am I missing?
Old May 11, 2004 | 02:46 PM
Z-ZANY's Avatar
Z-ZANY
Default what am I missing?
Trying to get drivers door panel of an 88. Got all screws, I'm pretty sure including the two under the doorlight. Got the manual doorlock cover off and it seems like the power lock button is holding it. can't see how to free that up. Can someone let me know what I'm missing? I don't want to break anything. Thanks, Jim :banghead:
Old May 11, 2004 | 04:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: what am I missing? (88 ragtop vette)
There are the screws around the carpeting, those around the Bose speaker, one above the hatch release, two in the door pull area and one behind the inside handle.
You then need to pry the plastic lock housing off the lock lever.
Then you can lift the panel up off the door frame and slide if forward slightly to clear the lock lever.
Then you need to tip the panel toward you so you can open all the electrical connectors and remove the two screws holding the lock switch to the back of the panel.
Before you install the panel wrap a little A/C weather strip tape around the hard connectors to keep them from rattling.
Old May 11, 2004 | 10:08 PM
Z-ZANY's Avatar
Z-ZANY
Default Re: what am I missing? (65Z01)
65Z01, thanks very much, I quess I had all the screws out and was being over cautious when I got some resistance. I will try it again. Thanks again. :cheers:
Old May 14, 2004 | 04:08 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
The lock lever plastic piece pulls UP off of the lock lever rod and slips out. Make sure you get all of the screws in the handle area, including the one pointing up behind the handle. Then the door panel comes off exactly as 65Z01 says.
To what am I missing?
