Radio
Old May 11, 2004 | 04:07 PM
Stingray1970's Avatar
Stingray1970
Default Radio
After winter storage the radio works intermittently ( may or may not come on). The display doesn't light and the antenna stays down. however, the clock will rigister if the on-off **** is pushed. Checked everything obvious, hope someone has a suggestion before i take it out for repair. It's a gold Bose. Any input is appreciated.
Thanks :banghead:
Old May 11, 2004 | 06:35 PM
zog's Avatar
zog
Default Re: Radio (Stingray1970)
You can do what I did...pull the bose and put in an aftermarket and new speakers...problem solved and better sound, too!!!! :seeya
Old May 11, 2004 | 08:18 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Replace the clk/ctsy fuse. Worth a shot. Not sure on yours, but on my 86 is supplys power to bose amp relay and power antenna relay
:cheers:
To Radio
