No start
Old May 12, 2004 | 01:26 PM
Swirk's Avatar
Swirk
Default No start
Yet another "no start" topic. This one is unique. It's not VATS, it's not the starter, it's not the battery. Here is the situation:
Put the key in the lock, turned the key, nothing. The lights come on, the security light does not flash, radio comes on. Try to turn it again, nothing. Check to make sure clutch is all the way in, nothing. Take the key out, retry. Nothing. Pop the hood, run a wire from the starter to the ignition relay (behind the battery), car starts right up.
While I am glad I can get it started, I would much rather use the key to start it instead of hot-wiring it.
Could it be the starter solenoid? The key lock itself? Any suggestions are appreciated.
This is on a 1990 6-speed.
Old May 12, 2004 | 01:49 PM
ZylaRace's Avatar
ZylaRace
Default Re: No start (Swirk)
Neutral saftey switch / ignition switch Both the same in my book.
When you twist the key, you are moving this switch. Should be mounted on the column, in the footwell area.
Old May 12, 2004 | 02:07 PM
Cherry6speed's Avatar
Cherry6speed
Default Re: No start (ZylaRace)
Did you by-pass the safety switch? I am leaning to the starter solenoid because that is what you bypass if you jump to the starter. The safety switch interrupts the key and if the safety switch were bad you would not be able to key start it; even if you by bypassed the solenoid :)
Old May 12, 2004 | 03:08 PM
Swirk's Avatar
Swirk
Default Re: No start (RUBYREDVETTECARD)
The safety switch is bypassed (thanks to the previous owner). When I turned the key, it smelled like something fried in there. I was talking with my buddy, he was in the car with me, and he just told me that he saw smoke coming out of the keyhole. So I am leaning towards the lock itself.
Old May 12, 2004 | 03:43 PM
Cherry6speed
That's not good....you can't properly track electrical problems with factory diagrams on modded wiring. I suggest you get the diagrams, find out what was changed, restore it to stock wiring;including safety switch. Then, you have a chance to work on the other stuff like the key switch. If not, you may find yourself frying a new switch. My .02 cents :seeya
Old May 12, 2004 | 04:33 PM
Swirk's Avatar
Swirk
Thanks for the advice. I will work on it this weekend. This could turn into a large project, dependingon what was cut.
To No start
