Where is the location
Old May 13, 2004 | 01:23 AM
Jinxie's Avatar
Jinxie
Default Where is the location
of the thermo time switch for the cold start valve on a 86?
Thanx
Old May 13, 2004 | 02:32 AM
rodj's Avatar
rodj
Default Re: Where is the location (Jinxie)
Is there one?
I thought the cold start function was controlled by the ECM as a result of the temps it sees from it's sensor
Old May 13, 2004 | 06:58 AM
Pete K's Avatar
Pete K
Default Re: Where is the location (rodj)
The switch is located on the front of the intake manifold next to the coolant temp switch. The thermo switch is the one with the square connector that resembles an injector plug
Old May 13, 2004 | 10:52 AM
Jinxie's Avatar
Jinxie
Default Re: Where is the location (Pete K)
Great....THANX!!
To Where is the location
