help - temp cooling sensor and ac problems
Old May 13, 2004 | 11:52 AM
quiksilver458's Avatar
quiksilver458
Default help - temp cooling sensor and ac problems
Hey guys... About a week ago I installed a smog elim kit from R&D racing.. Something I picked up from Dave a while back... While doing this, i replaced the PS resovoiur, and all the hoses ect. for the power steering.. A few days later, i notice my AC is not blowing cold air.... While im trying to figure this out, for some reason or another, i discovered my fan was not turning on, which was creating a engine cooling issue. I began to tackle the fan cooling first for i feel it is more important. I check the motor - it is good - checked the relay - it is good - grounded the sensor, fan turned on. I plan to buy a kit to reduce the temp to 180-185. My question is... When i get the fan working again, will my AC work? I remember reading something a while back about to much head pressure in the condensor will cause it to shut off? Can someone please enlighten me on this. I would greatly appreciate it.
:cheers:
Old May 13, 2004 | 02:13 PM
bogus's Avatar
bogus
Default Re: help - temp cooling sensor and ac problems (quiksilver458)
is there a chance you damaged the connector to the compressor? more accurately, the AC clutch?
I would say there is a corellation between the two problems. Check the relays from the AC system... they control fans, too.
Old May 13, 2004 | 11:12 PM
quiksilver458
Default Re: help - temp cooling sensor and ac problems (bogus)
Bogus, I checked wires to the AC clutch ect.. everything looks to be in good shape and connected.. I will mess with the relays and stuff tomorrow.. Hopefully I will figure something out.. Thanks!!
To help - temp cooling sensor and ac problems
