Brake pad replacement
Old May 14, 2004 | 03:55 PM
my1st_vette84's Avatar
my1st_vette84
Default Brake pad replacement
My Haynes repair manual says that for 84-87 Vettes, the self-locking caliper bolt must be replaced with a new bolt when the pads are changed. I've heard that there are some errors in the Haynes books...Do I have to replace that bolt on the caliper when I replace the pads?
Old May 14, 2004 | 04:14 PM
rick lambert's Avatar
rick lambert
Default Re: Brake pad replacement (my1st_vette84)
You should,I believe there a self locking type ;)
Old May 14, 2004 | 05:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My '88 GM Shop manual says to replace the caliper bolt & crush washer when you remove the caliper, e.g. to replace a caliper or rotor.
For front pad replacement only: replace & lube the caliper pin & c-clip, put some anit-rattle compound on the back of the pads and replace the pad clips.
If you have a bolt on the rear brakes that must be removed to replace the pads, replace it with a new one.
Then bed the new pads properly to avoid glazing.
Old May 14, 2004 | 06:50 PM
my1st_vette84
Default Re: Brake pad replacement (65Z01)
What do you mean bed the new pads?
Old May 15, 2004 | 02:26 AM
BIG JIM 54's Avatar
BIG JIM 54
Yeah...
The book says to replace the TPS adjustment screws if you loosen them too. I've loosened them 25 times now or so and they tighten just fine. And so do my caliper bolts I've taken off twice now as well. I think GM is in the fastener business.
BIG JIM
Old May 15, 2004 | 11:38 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
If you got the extra $$, buy the bolts. Personally I don't trust reusing mine, only because they have been off and on so many times, some with power tools other by hands. My next brake job will have me replacing the caliper bolts, front and rear. Of course I'm replacing everything except the calipers.
If you are just changing pads on the front, you don't have to remove the bolts holding the caliper bracket, just remove the pin, slide the caliper out and replace.
Old May 16, 2004 | 12:35 AM
fixit's Avatar
fixit
Default Re: Brake pad replacement (Mr Mojo)
If they don't appear to be abused simply apply some blue loctite and torque.
To Brake pad replacement
