Obstruction with AFPR?
Old May 15, 2004 | 12:46 PM
gene284's Avatar
gene284
Default Obstruction with AFPR?
After installing my Adjustable Fuel Pressure Regulator, when I went to put the plenum on, there is a problem.
The plenum hits on the top edge of the can on the AFPR.
As this can is aluminum, did you just file (radius) the edge a little to obtain clearance?
Perhaps yours already had a radius on this upper edge?
Just wondering what others have done, or did they even have this problem?
Can post a picture if you need one due to my poor description of problem.
Old May 15, 2004 | 01:10 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: Obstruction with AFPR? (gene284)
I didn't have any clearance problems with mine. I wonder why yours is hitting?
Old May 15, 2004 | 01:26 PM
FlyboyZR1's Avatar
FlyboyZR1
You must have the Holley AFPR.
I also had this problem with the adjustement **** on the regulator hitting the back edge of the plenum. I took a dremel too the plenum to give it some extra clearance.
Take a dremel to the plenum and you should be fine.
Old May 16, 2004 | 09:39 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My Holley just clears. I adjusted fuel pressure before I installed plenum. Maybe once you have adjusted it, there will be clearance. Mine is set for 43lbs with no vacuum and I have about 3/32" clearance.
:cheers:
To Obstruction with AFPR?
