Vacuum leak with my superram
Old May 15, 2004 | 08:20 PM
calebchoson's Avatar
calebchoson
Default Vacuum leak with my superram
Damn today i was suppose to get my 89 corvette back after a month and a half without it. My mechanic started it up and the idle was off, well i knew that i would need to adjust the tps setting and iac, but than the mechanic told me the engine turned off and that there was a vacuum leak in the gaskets provided with the superram. He used two tubes of black rtv where indicated and let it set longer than 24 hours. So now he has to take the whole thing apart again and use some Permatex Hylomar, which he would have used when he first put it together but there was a note from lingenfelter saying not to use any sealants. So he thought the gaskets would hold, but nope it started leaking. This is very frustrating :mad
[Modified by calebchoson, 1:20 AM 5/16/2004]
Old May 15, 2004 | 08:25 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: Vacuum leak with my superram (calebchoson)
I feel your pain. I just finished my SR install this past week. One of the only things that DIDN'T go wrong was I actually had no vacuum leaks. I used Permatex Black with the gaskets and it worked just fine. How much are you paying a mechanic to do this for you? While re-doing the plenum is time consuming, you could easily do it yourself and save some money. Just an idea.
Old May 15, 2004 | 08:49 PM
calebchoson
Well actually my mechanic will probably charge me 1000 or more dollars but i have 655 dollars upfront. He told me he is not going to charge me for this situation that occured because if he was i would be sweating bullets. :banghead: I need my car back :auto:
Old May 15, 2004 | 09:34 PM
flyersfan1088
Well, that's good. Consider yourself lucky he's not going to charge you for the extra time. :cheers:
Old May 15, 2004 | 09:55 PM
chucks88's Avatar
chucks88
..............He used two tubes of black rtv where indicated..................
:shocked:
Old May 15, 2004 | 10:04 PM
flyersfan1088
Default Re: Vacuum leak with my superram (chucks88)
:shocked:
I didn't even catch that the first time. 2 Tubes?! You must have RTV oozing out all over the place!
Old May 15, 2004 | 10:29 PM
calebchoson
well thats what he told me
Old May 16, 2004 | 12:50 AM
1990CORVETTE's Avatar
1990CORVETTE
Default Re: Vacuum leak with my superram (flyersfan1088)
:shocked:
Dude send me a IM,,,, 2 tubes of sealant...... :shocked: :shocked:
WTF
who is doing this???????????????????
Old May 16, 2004 | 02:20 PM
86Moon's Avatar
86Moon
Default Re: Vacuum leak with my superram (1990CORVETTE)
Kinda depends on the size of the tubes here, don't you think guys :nono: Let's not rile this poor fella up anymore than he is already. He'll soon learn that he needs to come here first.
If the intake is leaking, look for THE RIGHT STUFF and take it to your mechanic. Do a search on the forum and get the right proceedure's. I think there has been a dicussion of this in the last few days. Poke around a little :seeya
To Vacuum leak with my superram
