"""REMOVING PLENUM PIPES ON 85""
Old May 16, 2004 | 03:53 PM
chillcat's Avatar
chillcat
Default """REMOVING PLENUM PIPES ON 85""
I've removed the passenger side blow pipes and the plenum...I can't seem to figure out how to remove the fuel rails to get to that last bolt holding the drivers blowdown pipe..I'm having them polished...thanks
Old May 16, 2004 | 04:10 PM
bogus's Avatar
bogus
Default Re: """REMOVING PLENUM PIPES ON 85"" (chillcat)
Blow pipes? what are they? :confused:
Old May 16, 2004 | 04:24 PM
pipe's Avatar
pipe
Default Re: """REMOVING PLENUM PIPES ON 85"" (bogus)
Maybe he means the runners :crazy:
Old May 16, 2004 | 04:34 PM
86PACER's Avatar
86PACER
You do not need to remove the fuel rail to remove either runner.
I beleive you are refering to the last runner bolt closest to the firewall on the Driver's side. If it's the one on the back side, you can get to it using an extension and a torx bit from the passanger's side of the motor. If it's the one on the outside, that one is just simply a PITA. I use a flexible joint with several small 1/4" drive extensions and work it under the wiper motor housing from the Driver's side. Good luck.
Old May 16, 2004 | 04:58 PM
chillcat's Avatar
chillcat
Default Re: """REMOVING PLENUM PIPES ON 85"" (86PACER)
Got it......thanks alot...
To """REMOVING PLENUM PIPES ON 85""
