fuel pressure mod q's
Old May 16, 2004 | 07:26 PM
956spd's Avatar
956spd
Default fuel pressure mod q's
I was looking at the tech articles on the free fuel pressure upgrade. So I was thinking of trying it on my 95 lt1 but was also wondering how pulling off that vacum line would make the car run richer and not leaner. :auto:
Old May 16, 2004 | 07:58 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: fuel pressure mod q's (956spd)
The fuel pressure regulator reduces fuel pressure as vacuum is applied. When you step on the throttle vacuum decreases, and increases fuel pressure. I would consider this "mod" entirely useless. At wide open throttle you will essentially have zero vacuum on the regulator anyway, thus you'll get maximum fuel pressure. At part throttle you'll be running higher fuel pressure than normal. The computer will see a richer exhaust and compensate by trimming the injector pulse width.
All this "mod" will do for you is trick the computer into thinking you're getting better gas mileage because it sees a smaller injector pulse width and doesn't know why.
