Does an 85 ecm have a rev limiter?
Old May 16, 2004 | 09:37 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Does an 85 ecm have a rev limiter?
Does the 85 corvette ecm have a rev limiter and if it does what is it set for............I seem to be hitting a wall at 5900 rpm or so........super ram with procharger .......brand new engine .......no tune........just woundering were to start looking.
Old May 16, 2004 | 09:44 PM
zelement's Avatar
zelement
Default Re: Does an 85 ecm have a rev limiter? (lead foot 85 vet)
I was told that they do not. What kind of chip do you have? COuld be set in the chip.
I have a similar problem with my 91 but it happens at around 6600rpm. I replaced the distributor with a DUI unit and I got a little more RPMs out of it but it is still there. I have gotten it to rev to 7000rpm a few times but it rarely gets up there without cutting out first.
What kind of distributor do you have? It could be just the stock HEI dying out.
[Modified by zelement, 8:45 PM 5/16/2004]
Old May 16, 2004 | 09:54 PM
MrNuke's Avatar
MrNuke
Default Re: Does an 85 ecm have a rev limiter? (zelement)
They don't have a Rev limiter, but the stock eprom has a Fuel Cutoff programmed at 12,500rpms..
Old May 16, 2004 | 10:54 PM
lead foot 85 vet
Default Re: Does an 85 ecm have a rev limiter? (MrNuke)
stock chip............stock distrbutor and coil........with a MSD 6A...............its in a very rough state of tune just wanted to rule the ecm out.........thanks for the help guys. :yesnod:
Don't think I'll hit the fuel cutoff soon :D
Old May 16, 2004 | 11:37 PM
scorp508's Avatar
scorp508
You don't consider a fuel cutoff a rev limiter? :confused: The short answer is "yes it has one" the long answer is "it isn't set at a level to be overly effective in the stock setup."
Old May 16, 2004 | 11:47 PM
zelement's Avatar
zelement
Default Re: Does an 85 ecm have a rev limiter? (scorp508)
I think what he is saying is that the "ECM" doesn't have one but the "Chip" itself does.
Leadfoot,
I think your stock module and coil cannot keep up
[Modified by zelement, 10:48 PM 5/16/2004]
Old May 17, 2004 | 12:11 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Thats good. So when the bottom end is blotto, the fuel will cutoff. Thats some engineering feat!
Old May 17, 2004 | 12:15 AM
scorp508's Avatar
scorp508
Default Re: Does an 85 ecm have a rev limiter? (JrRifleCoach)
Not really, the stock TPI intake won't let it spin high enough to break. :rofl:
Old May 17, 2004 | 02:06 AM
JrRifleCoach
I thought we were talking fuel pump RPM... :lolg:
To Does an 85 ecm have a rev limiter?
