I have Comp. Cams ProMagnums and set zero lash plus 5/8 turn.
I've found that the adjustment between just feeling drag and not being able to twirl the push rod is ~1/8 turn; so my accuracy on zero lash is +/-1/8 turn. If I adjust lash to zero lash plus 5/8 turn I'm between 1/2-3/4 turn.
Further, I take the long route to assure the valve is on the base circle. I turn the crank till the exhaust valve is just opening and adjust the intake; I then turn the crank till the intake is just closing and adjust the exhaust.
The only way I can do it, is with the engine running. Then, you can do it by ear. You'll hear it in the engine. When all is well, the engine will be nice and smooth, and quiet.
I'll let someone else explain the static way, since I stink at it.
:iagree: There is no better, more accurate way of determining zero lash, then when the clack of the lifters, just stops. But you have to have some sort of initial setting to get it running. 65Z01's method of static preload is perfect. Too many people miss the true zero lash, by spinning or rattling the push rod. Identifying zreo lash while running is "fool proof".
