91 4l60e in 94??
Old May 18, 2004 | 10:07 PM
underpressure78's Avatar
underpressure78
2nd Gear
Default 91 4l60e in 94??
will the trans from a 91 vette work in a 94 vette, or did they change the connectors on the plugs. thanks
Old May 18, 2004 | 10:29 PM
Siveck's Avatar
Siveck
Default Re: 91 4l60e in 94?? (underpressure78)
The '91 used a 4L60 (700R4) and the '94 used the 4L60e. The e stands for electronic shift control. The change was made somtime in '93. The 4L60 uses a throttle valve cable instead. You could make it work, but it is not worth it and I think the elctronic version is better anyway because those tv cables can be so troublesome.
Old May 18, 2004 | 10:34 PM
underpressure78
2nd Gear
just wanted to make sure, iremember my 90 had the cable to adjust. i was posting for a friend whose 383 tore up a stock 4l60 e in his 94. thanks ill tell him to keep looking
To 91 4l60e in 94??
