Accel GEN7 DFI systems
Old May 19, 2004 | 11:55 AM
tjwong's Avatar
tjwong
Default Accel GEN7 DFI systems
Anyone interested in getting a GEN7 DFI system? If so email me off list I maybe able to save you some $$$
Old May 19, 2004 | 10:38 PM
GM_96LT4's Avatar
GM_96LT4
Default Re: Accel GEN7 DFI systems (tjwong)
TJ,
Does that include the 454/502 systems as well?
Thanks in advance,
Glenn
Old May 20, 2004 | 09:50 AM
tjwong's Avatar
tjwong
Default Re: Accel GEN7 DFI systems (GM_96LT4)
Yes it does if interested shoot me an email and I will give you the particulars
Old May 20, 2004 | 04:06 PM
mn_vette's Avatar
mn_vette
Where were you 3 months ago???
Old May 21, 2004 | 12:00 AM
tjwong's Avatar
tjwong
Default Re: Accel GEN7 DFI systems (mn_vette)
Sorry But it wasn't until recently that I got in with Mr. Gasket but if I can help you with anything else feel free to email.
Old May 21, 2004 | 12:54 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Tom, do you know if you can mix ignition pickup signals, ie. can you use a hall effect crank trigger with an inductive pickup cam signal ?
How do you like the wideband option ?
Old May 21, 2004 | 01:02 PM
tjwong's Avatar
tjwong
Default Re: Accel GEN7 DFI systems (SloRvette)
You know thats a very good question. Yes you can do that. In the G7 ECU set up screen you can define the ignition inputs there. I do like the WBO2 system that Accel offers but I think they should drop the price. It does use a NTK sensor that is not unlike the sensor that my Horiba uses. They tell me that its equal to my Horiba sensor, and I can say that its accuracy is on par when I have the systems side by side sampling the same exhaust pipe.
Old May 21, 2004 | 01:21 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Tom.......Mac at fasttrackperformance told me that the innovate wideband o2 senser would work with the gen 7 and save some bucks over what accel is charging for the o2 option.
Old May 21, 2004 | 03:35 PM
mn_vette's Avatar
mn_vette
Default Re: Accel GEN7 DFI systems (lead foot 85 vet)
The innovative system will work and the accel system will work, but they will not work TOGTHER. The whole point of having the wideband O2 system integrated into the computer is so that it can adjust fuel on the fly, innovative won't do that, it's only good for the initial tune. I've talked to several people that have had their engines saved because their wideband O2 compensated for a fuel pump going out or an injector not keeping up to speed. And the fact that its just alot nicer to deal with one system.
Oh, and just to let you know, I've tried the Innovative system with my accel. The wideband box was faulty when I got it so I used that as an innitial tuning device. It's hard to do a run and then compare the datalogging from the accel to the datalogging from the innovative system.
Old May 21, 2004 | 05:24 PM
lead foot 85 vet
I hear you I have both also.............but I talked to him yesterday and he said you could intagrate the innovative system into the gen 7 system with a wire harness and it would work just like the gen 7 WB02....if it soesn't work automaticly with the gen 7 fuel air correction system then there's no point in using it...............just passing information............maybe if your interested......give him a call.......888-640-3278
what was wrong with your innovate wide band? and I hear you on tuning on the fly......I don't have time to look at all the gadges .........at least at WOT
Old May 29, 2004 | 03:53 AM
tjwong's Avatar
tjwong
The Innovate system will work with the DFI system. The Innovate has 2 programmable analog outputs. All that needs to be done is to calibrate the Innovate system so that it meets the requirements of the DFI system. The DFI system will accept the signal as it doesn't care what the source is and as long as its calibrated to what the DFI needs for a signal it will be just as accurate as the DFI wide band system. The best part is that its more than half the cost of the DFI WBO2 As soon as I get my hands on a DFI system I will try to interface one of my Innovate systems to the DFI ECU.
Old Jun 10, 2004 | 01:28 AM
HvyHitr's Avatar
HvyHitr
Sent you some mail.
Old Jun 10, 2004 | 04:36 PM
scorp508's Avatar
scorp508
I wish, I'm just poor.
Old Jun 23, 2004 | 06:28 PM
John G 92's Avatar
John G 92
Can you get a deal on the super ram intake package with the dfi system? if so how much email me at xxxirocz88xxx@aol.com thanks...
Old Jun 23, 2004 | 10:44 PM
tjwong's Avatar
tjwong
Default Re: Accel GEN7 DFI systems (John G 92)
You got mail. Plus I have a bit of news for all you DFI GEN7 owners that want a WBO2 sytem but can't seem to justify the Accel WBO2 systems healthy price tag. I have sucessfully integrated the Innovate WBO2 system to the GEN7 systems I am finalizing my calibration curve tonight and I will begin sourcing cabling to make the installation a piece of cake. So that means for a bit more than $350 you can have a functional WBO2 integrated into your GEN7 DFI system to be able to tune on the fly and make corrections. Then once tuning is done the sytem can be returned back to a narrow band system.
Old Jun 27, 2004 | 01:59 PM
Brand-X's Avatar
Brand-X
Tom,
I may need to buy a Gen VII+ key, ever since my move to Atlanta, can't seem to find anything. How much are those things going for these days?
Chris
Old Jun 29, 2004 | 11:57 AM
tjwong's Avatar
tjwong
Default Re: Accel GEN7 DFI systems (Brand-X)
Chris do you need the sportsman or the pro key?
To Accel GEN7 DFI systems
Old Jun 29, 2004 | 06:53 PM
Brand-X's Avatar
Brand-X
It's no longer an issue...Thanks, Chris
[Modified by Brand-X, 5:53 PM 6/29/2004]
Old Jun 30, 2004 | 10:14 PM
'68LT1camaro's Avatar
'68LT1camaro
3rd Gear
Hey TJWONG, I am interested in using an LM-1 with my Gen 7 DFI set up. I talked to MAC yesterday, and he said he makes a harness to connect the LM-1 to the DFI harness. He said he sells the harness with the LM-1 for $350. What did you have to do exactly to get this WBO2 to work with your Gen 7?
Any help would be greatly appreciated!!!
[Modified by '68LT1camaro, 3:15 AM 7/1/2004]
[Modified by '68LT1camaro, 3:17 AM 7/1/2004]
Old Jun 30, 2004 | 11:15 PM
tjwong's Avatar
tjwong
Default Re: Accel GEN7 DFI systems ('68LT1camaro)
Basically I fed a signal into the GEN 7 system after defining its usage with a linear O2 sensor. I figured out what the curve was that the G7 system was expecting to see from the WBO2 box. I also got the information from Mac as well, and for what he is selling the Innovate for is a good deal. I don't have the harnesses made up yet to make the connections to the G7 system. I am awaiting my connectors. Basically all the harness consists of is the mating connector to the G7 O2 connector, and a analog output cable for the LM1 which is just a 1/8" stereo headphone cable with a phono plug on the end just like what is used on your walkman. I just don't have the O2 sensor connectors at this time.
Mac and I have some disagreement on what values to use in the programming of the LM1. He told me that his engineer figured it out and gives a voltage spread of about 2.30 volts. I simulated a signal to the G7 O2 input with a special instrument calibration simulation tool. I found that the G7 wants to see a input voltage of 1 to 5 volts, which equals to 10.08 to 19.18 AFR. So what Mac has sent me and what I seen in the G7 systems don't match.
The only discrepency is perhaps how they set up the internal programming of the G7 ECU. With my calculations I set it up for a linear type 2 sensor. I had no way of using a live test on an engine to test what I found to compare what is displayed on the LM1 vs the G7 dashboard. But I feel 99.99% sure that what I found will be accurate and will work. I had over 50 datapoints to plot the curve by and it was definitely repeatable as well.
