Would a code 32 cause the car to run rough?
Old May 21, 2004 | 12:24 PM
montie98's Avatar
montie98
Default Would a code 32 cause the car to run rough?
Hello, My buddys 89 starts to run poorly once it is warmed up. I pulled the codes and got a 32(egr)?
Old May 21, 2004 | 01:20 PM
rick lambert's Avatar
rick lambert
Default Re: Would a code 32 cause the car to run rough? (montie98)
Alot of guys have had success just replacing the egr switch, but check the connections and check for vacumn leaks. Hopefully this will solve the problem. But it could also be the ECM. :thumbs:
Old May 21, 2004 | 01:36 PM
dgoodhue's Avatar
dgoodhue
If the EGR valve itself is sticking open then it would cause a bad idle.
To Would a code 32 cause the car to run rough?
