TB bypass caps LT4
Old May 23, 2004 | 01:39 AM
larryfs's Avatar
larryfs
Default TB bypass caps LT4
I'm doing the TB bypass.
where could I get the caps to seal off the TB?
are they 3/8"?
Old May 23, 2004 | 07:30 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Default Re: TB bypass caps LT4 (larryfs)
Yes, they are 3/8" I believe. You should be able to find an assoertment of plugs, such as vacuum port plugs, at some part stores. I used plastic caps that cover fittings and the like on new parts I install at work.
Old May 23, 2004 | 08:50 AM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I just picked up an assortment at the local hardware store.
Old May 23, 2004 | 02:24 PM
JasonL's Avatar
JasonL
Default Re: TB bypass caps LT4 (LT-4 CE)
You can find various size caps at any auto parts store. They are made by "Help!" brand.
Old May 23, 2004 | 03:44 PM
JB666's Avatar
JB666
That's all I did, too..
Old May 23, 2004 | 04:35 PM
gt306's Avatar
gt306
Do you actually gain anything by removing the TB hose? I though it was better to keep on it to cool the tb...
Old May 23, 2004 | 05:03 PM
Strick's Avatar
Strick
Default Re: TB bypass caps LT4 (gt306)
The function of the coolant going through the TB is to keep ice from forming in the TB during the cold wet weather. The coolant runs around 200 plus or minus a few and the idea of the bypass is to eliminate the hot coolant from heating up the TB in hot weather which reduces your horsepower, hot air is less dense than cold air. Some say it works some argue it doesn't.
Old May 23, 2004 | 07:20 PM
Wayne88's Avatar
Wayne88
I bought mine at Pep Boys, they were hanging on the shelf,
packaged 2 per package.
Cost $1.99, I used 5/8, they fit perfect.
I believe the hose-to & from-the TB is also 5/8.
:cheers:
PS Mine is an '88.
[Modified by Wayne88, 7:21 PM 5/23/2004]
Old May 23, 2004 | 10:44 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Default Re: TB bypass caps LT4 (Wayne88)
I did the bypass..cheap, easy, why not?? ...But does cold air make that much difference?? If it did I think we'd all be running a bootleg hose from an ac vent to throttle body...Can you believe I actually ponderd ways that could be done at one point?? :lolg: and if you think thats funny..you'd really like my thoughts on a "poor boys" supercharger! lol!
[Modified by skateparkdave, 10:17 PM 5/23/2004]
Old May 24, 2004 | 01:32 PM
Wayne88's Avatar
Wayne88
That's a good question.
My TB gets hot, probably hotter that the coolant that would pass thru it.
Old May 24, 2004 | 02:30 PM
Perfusion's Avatar
Perfusion
I never capped my TB after doing the bypass.
To TB bypass caps LT4
