Maybe a stupid electrical question...
Old May 23, 2004 | 11:44 AM
cyberblast's Avatar
cyberblast
Default Maybe a stupid electrical question...
When i follow some tech-articles, i need to disconnect the battery, because of disconnecting some electrical stuff or whatever...
Is there an alternative for disconnection the battery? maybe to pull a fuse?
:bb
Old May 23, 2004 | 11:58 AM
1MoorTym's Avatar
1MoorTym
Default Re: Maybe a stupid electrical question... (cyberblast)
Pulling a fuse only kills power to a single circuit not the whole car.
Disconnect the battery to be "safe".
Old May 23, 2004 | 12:01 PM
tjwong's Avatar
tjwong
Depending on what you are doing, taking a minute of time to disconnect the negative battery cable can potentially save your hundreds of dollars :) For instance, a new PCM should you fry that can cost you $150 plus dealer costs for a reflash, if you have an older car the cost is about the same for the parts. Not to mention lost time behind the wheel :)
Old May 23, 2004 | 12:33 PM
cyberblast's Avatar
cyberblast
Default Re: Maybe a stupid electrical question... (tjwong)
i want to replace the window outer seals...
ok, so i only need to disconnect the negative cable? or just the negative first?
[Modified by cyberblast, 6:58 PM 5/23/2004]
Old May 23, 2004 | 12:40 PM
tjwong's Avatar
tjwong
Yep, just the negative cable will do the trick. Plus thats the easier of the two to get to :)
Old May 23, 2004 | 12:59 PM
cyberblast's Avatar
cyberblast
thank you very much for helping!
best regards, martin
[Modified by cyberblast, 7:00 PM 5/23/2004]
[Modified by cyberblast, 7:19 PM 5/23/2004]
To Maybe a stupid electrical question...
