Is this a 'normal' AC problem??
:cheers:
:seeya
[Modified by SunCr, 2:45 PM 5/27/2004]
My guess is you are experiencing the initial stage of Opti failure. This is a pretty common symptom. Next stages are more pronounced miss at speed and jumping idle rpm.
I'd CONSIDER it to be an opti problem if it did it with the AC ON OR OFF, but, it's only with it ON. When it's off, the car purrs... :smash: Plus, when it 'cuts' out a little bit, I can hear the AC cycling on/off under the hood.
You are right though, on the highway, in 6th, I don't feel it. It's mostly low speeds under a load.
It sounds like the same problem I have with my 1992 Corvette.
When I am driving, it "feels" like the AC compressor is switching on and off about once every 10 to 20 seconds. My temporary solution has been to just not use the AC.
Worse case, if no one has a solution, I need to take the Corvette to the shop in the next few weeks anyway, I will find out what the deal is with this surging problem. It will be a few weeks though. Hopefully before then, someone will reply with a solution to your problem.
I have had to replace the lower one because it was stuck at a low pressure setting. There is also an adjustment screw in the switch wire connector that lowers the pressure that the unit will shut off at. I had to have mine adjusted to run R134 in my 86.
In any event, its best to have an reputable AC tech check the system before making any adjustments. The freon and oil levels need to be correct before anything else. You could mistakenly mask a problem that will cost big $$$$ down the road.
Up until '90, most will feel the compressor cycle at idle as the ECM gets it's a/c signal from the compressor or the a/c control panel. That creates just enough of a delay for the IAC to be a tad behind compressor clutch engagement. For '90 and above, GM redesigned the system so that the ECM controls clutch engagement giving it much better control over idle quality.
At peak efficiency, which for an a/c system is anything above an engine speed of 1200 - 1500 rpms and a vehicle speed of 25 mph, the clutch may cycle as the increased air flow across the condensor reduces system pressures. It would be unusual to feel this as the load on the engine is no more than 1 to 2 hp. If it is felt, suspect other problems such as a worn compressor or compressor clutch or a plugged up orifice. I wouldn't necessarily consider it a low charge - particularly on a 90 or up where the ECM will shut down a/c operation if the pressure switch sends a voltage signal indicating a low charge and for these later years, set a trouble code. In any event, debris in the orifice raises the high side; reduces the low side and you won't get a trouble code because the pressure switch signal to the ECM is on the high side.
If the pressure gets too high - above 425 psi, the switch is going to shut it off to keep it from blowing up.
You should be able to reproduce excessive cycling in the garage. Hold the throttle open with a washer so that the engine is running at 1200 to 1500 rpms. Get the fan running. Up until 89, you can disconnect the fan switch on the high pressure line. For '90 and above, both fans should allready be running, but if they're not, ground the relays so that they stay on. You can also put a fan in front of the car, but with a bottom feeder like a Vette, it doesn't do a lot of good but you need to get as much air as you can flowing across the condensor. In any event, if the compressor cycles more than 8 times in a minute, there's a system problem.
Once it's cycling, observe the clutch for slippage (On the '92 and above that might be little difficult but you need to get a good look at it). If it is slipping, check the air gap with the engine off. There should be a clearance of .020 between the drive plate and the pulley. Any greater and it increases compressor load (and wear) and it will also make a much louder noise when it engages.
To see if the orifice is plugged, you really need to see what the pressures are. Otherwise, look for ice on the high side line 3 or 4 inches before the evaporator or just below and around the nut that connects the high side line to the evaporator (it's the line at the bottom). Feel the line where it enters the evaporator (right where the line enters too - much higher and you can burn your hand) along with the top line. Both should be cold with the upper line maybe a tad cooler. You can measure the temp with a digital meat thermometer if you want. The temp isn't terribly important, but both should about the same and below the outside air temp. Post what you find out/observe for addt'l help.
