Service engine light code patern... I need the error code??
Old May 23, 2004 | 07:55 PM
TheStef's Avatar
TheStef
Default Service engine light code patern... I need the error code??
Hi guys,
I just did an error code test on my 88 Vette, with the Pin connect A and B with the paper clip, but I need to know the error codes for these two flashing paterns.
Unfortunaly I do not have the service manual to find out.
First code is, (Flash, Flash, Flash, Pause, Flash, Flash, Flash)
Secound code is, (Flash, Pause, Flash, Flash)
Thanks guys! :cheers:
Old May 23, 2004 | 08:09 PM
MPforUSMC's Avatar
MPforUSMC
Default Re: Service engine light code patern... I need the error code?? (TheStef)
Code 33: Manifold Absolute Pressure Sensor (MAP)-signal voltage out of range, high or Mass Air Flow (MAF) sensor-signal voltage out of range, probably high.
Code 12: No Engine RPM reference pulses-System Normal
[Modified by MPforUSMC, 1:10 AM 5/24/2004]
Old May 23, 2004 | 08:11 PM
TheStef's Avatar
TheStef
Default Re: Service engine light code patern... I need the error code?? (MPforUSMC)
Thank you! :thumbs:
vsocks's Avatar
vsocks
Where is there a complete ECM code listing?
I have codes 24 and 45, what are they?
Old May 23, 2004 | 08:18 PM
TheStef's Avatar
TheStef
Just want to make certain... did you get that error code 33 from an 88 Service manual? I read that there are differences depending on the year.
Old May 23, 2004 | 08:19 PM
TheStef's Avatar
TheStef
Here's the web site
http://www.c4vettes.com/ecm.htm#33
Old May 23, 2004 | 08:21 PM
MPforUSMC's Avatar
MPforUSMC
Default Re: Service engine light code patern... I need the error code?? (vsocks)
VSOCKS, I bought a code reader for 30 bucks at Checkers and it has a code booklet. Also, its in the Chilton repair book. And of all else fails, you can surely find it using the search button on CF. :flag
Code 24: Vehicle Speed Sensor Cicuit
Code 45: Oxygen Sensorleft side on 2 sensor system rich exhausted indicated
Old May 23, 2004 | 08:42 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The first is a code 33 == MAF reading high;
the second is code 12==end of trouble codes.
Old May 23, 2004 | 08:50 PM
1985 Corvette's Avatar
1985 Corvette
The trouble code 33 remained the same for models 1985 through 1989. I've heard that includes the 1990 model year as well, but I thought 1990 was the year MAP was introduced.
Old May 24, 2004 | 08:47 PM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Default Re: Service engine light code patern... I need the error code?? (1985 Corvette)
Yes, when they went to Speed/Density, the code 33/34 referred to the MAP instead of the MAF.
To Service engine light code patern... I need the error code??
